blue smoke on cold start up
Old Nov 8, 2007 | 02:08 PM
ryan10's Avatar
Hey guys, its starting to get cold here now, in the mornings its about 30 degrees out, and i dont plug my truck in yet. the truck starts 1/4 crank all the time, but it hazes a little bit of blue smoke at idle, then a little more when i drive away. its not too much smoke, i was just wondering if this is normal?
thanks.
Old Nov 8, 2007 | 02:17 PM
dizzel's Avatar
As long as it goes away when the engine warms a little your fine in my books. It's just cold, so you end up with unburned fuel.
Old Nov 8, 2007 | 05:23 PM
Check to see if you have power to the KSB solenoid.
Old Nov 9, 2007 | 05:36 AM
ryan10's Avatar
Ok, well the KSB is not working. what should i check?
thanks.
Old Nov 9, 2007 | 06:59 AM
Power Ram 250 C's Avatar
Check the intake temp sensor (closest to the firewall) with a lest light and see if you have juice coming into it. If you also have juice coming out of it going down to the ksb then check the wire plug that plugs onto the ksb solenoid. The intake temp sensor gets it's power from the fuel shut off solenoid. My problem was a bad intake temp sensor. Replaced it and it works fine. Here's the tab that has all the info. https://www.dieseltruckresource.com/...ht=ksb+problem
Old Nov 9, 2007 | 02:21 PM
ryan10's Avatar
OK, well i have power to one side of my intake temp sensor. is this how it should be? i dont have power to the solenoid thou. i changed out that solenoid with another that i have, but still nothing. what should i check next?
Old Nov 9, 2007 | 06:08 PM
You should have power across the switch to the KSB solenoid with a cold engine. The air temp switch opens at 90 degrees.
Old Nov 9, 2007 | 10:57 PM
ryan10's Avatar
OK, this is where im at. the sensor on the intake has power, on one side. Im assuming this is how it should be, and one side is a ground? when i disconnect the wire from the KSB tab, with the key on there is no power to the wire? should there be power there? also, the tab itself on the KSB does not have power with the key on? should this have power like the fuel shut off solenoid does? what should i check?
thanks
Old Nov 10, 2007 | 07:18 AM
The other wire on the temp sensor is supposed to be hot when the sensor is cold enough, so both should be hot. When working properly, the ksb solenoid will test around 12v.
Old Nov 10, 2007 | 05:20 PM
When the air temp switch is below 90 degrees, the KSB solenoid should have power if the key is on.
Billut
Jan 14, 2010 10:32 PM
ripping r
21
Aug 13, 2009 08:58 PM
77machomopar
Dec 5, 2008 04:41 AM
Micaiahfied
Jan 9, 2007 06:28 PM
dma251
Mar 22, 2004 10:26 AM
