Blown HG :(
Old Jun 3, 2010 | 05:21 PM
  #31
JQmile's Avatar
Just make sure none of them are at like 90 lb-ft. They're doing you no good there.
Old Jun 3, 2010 | 05:24 PM
  #32
92smokin blacky's Avatar
alright thanks for the help man. so 115 is comfortable? and go 125 if i think its fine?
Old Jun 3, 2010 | 09:12 PM
  #33
JustRamIt91's Avatar
humm... this seems like a GOOD weekend project that can turn BAD!!! esp with my luck...
Old Jun 3, 2010 | 10:32 PM
  #34
mhuppertz's Avatar
If I jam on mine and get anywhere near 40PSI I start squeezing antifreeze down the block! Got the ARP's, waiting for time and energy.
Old Jun 4, 2010 | 02:38 PM
  #35
big stinky's Avatar
Make sure you pull each bolt out and clean the threads on the head and the block and lube with oil. This is the most important part to get even torque across the head.
See my other post.
Old Jun 5, 2010 | 04:58 AM
  #36
Ramrod90's Avatar
how tight can you torque ARP studs without hurting anything? I just did mine (head gasket, 60lb VS, 4K kit) and i torqued the studs to 150. I have been driving for about a week now and they havent needed a retorque... When we did this project, we had the truck from running to running in 6 1/2 hours to include bottom tapping the block and doing all the other assorted tasks like valve seals. Could I potentially hurt something?
Old Jun 5, 2010 | 09:44 AM
  #37
CaptainChrysler's Avatar
ARP expressly says not to go over 125. That being said, we put them at 130 .
In my mind since the studs have a finer thread pitch on the top where the nut is, the same tq. would give you more clamping force?
I have went to 135 on the old non/IC bolts and they were fine. Like Big Stinky said make sure you have clean, oiled threads. Don't forget under the bolt heads, and where they sit on the head, that makes a huge difference. I prefer ARP lube on them. Try one dry, and then fully lubed, you will be amazed how much better they torque down.
Old Jun 5, 2010 | 02:21 PM
  #38
Just like i've always been taught. Turn it till it cracks and go 1/2 turn more
Old Jun 9, 2010 | 11:29 AM
  #39
dstad's Avatar
Hmm well getting close to having my finances straight. Il be getting the factory cummins marine grade gasket, mag-ing the head, oring it and then wait a while longer till ARP's are in my price range. Once i get it all put back together ill set the waste gate to 30psi. till i can get studs.
Old Jun 9, 2010 | 04:48 PM
  #40
yeah i peak to/past 40 TOO often....
soopertrooperII
Jan 12, 2004 11:28 PM
DEC
Nov 6, 2003 06:48 PM
DODGE4X4
Aug 2, 2003 08:28 PM
Chrisf
Jul 10, 2003 12:58 PM
erdoejr
Nov 20, 2002 01:25 PM
