Blown ignition maxifuse
Old Nov 18, 2002 | 09:01 PM
erdoejr's Avatar
I own a 1998 2500 turbo diesel which recently has been blowing the 30 amp under the hood maxifuse. This fuse protects the ignition circut (which I know when blown will not send power the starter). I first noticed this because the abs trouble light came on, along with the air bag light and then I noticed that the speedometer was not working either. Anyway any insight into this problem would be appreciated.
Old Nov 20, 2002 | 01:25 PM
Jrr's Avatar
Jrr
Re:Blown ignition maxifuse
Check for loose connections at starter and for frayed spots on cable. A loose connection can blow these fuses as well as a bad ignition switch.
db
Oct 9, 2008 01:49 PM
KATOOM
Apr 23, 2003 06:53 PM
D4Fritz
Mar 16, 2003 03:55 PM
Central Texan
Jan 15, 2003 12:22 AM
TX Ram
Jan 5, 2003 11:58 AM
