In a bind
Old Jun 10, 2006 | 09:14 PM
t8ter's Avatar
In a bind
My truck is running like it is in a bind.Kinda like its making power just not laying it down.Don't feel the tranny slippen.Mpg is still normal.It also has been running rough when I crank it in the morning or when it sets 4 awhile.I will try a new filter Monday.3200 spring is on way.Any ideas before I do the spring?
Thanks T8
Old Jun 10, 2006 | 10:19 PM
Sounds like you are getting air in the fuel system.
Old Jun 11, 2006 | 07:00 AM
t8ter's Avatar
Is there some way I can check this?Thanks a bunch.
Old Jun 11, 2006 | 07:04 AM
Use a rag wrapped around an air hose to put a few psi of pressure in the fuel tank. Air leaks will show up as fuel leaks. If that doesn't turn anything up, you can put a section of clear hose in the fuel line right before the lift pump and watch for bubbles.
Old Jun 11, 2006 | 10:10 AM
Falcon1's Avatar
What he said. But just a few lbs.
Greg
mikmaze
Aug 22, 2010 08:19 AM
12valvin
Sep 11, 2009 09:02 AM
BigGreen96
Jun 7, 2009 11:36 AM
Common
Mar 7, 2007 09:57 PM
Bad Ramer Jamer
Oct 22, 2006 10:09 AM
