BHAF/Smokey Mount
Old Mar 20, 2006 | 10:16 AM
ruquik's Avatar
BHAF/Smokey Mount
So i fabbed up as Old Smokey Mount friday, took about 6 hours from leaveing the house to the race car shop to driving w/ the new filter.
I love it but there are some things i would like to let people know (newbies) when it come to fabbing one of these up.
1) Use sheet that is .100 - .125, unless you want to make braces like i did because i used black race car body sheet metal (looks better in my opinion.
2) Use a 5" hole saw, it took 30-40 min. making 4.5" a 5" hole.
3). Clamp the sheet down to a 2 x 8 and use 2 x 2 on top to straddle the hole, beacuse it grabs very easily and chatter to no end
4) Remove the rad. over flow as well as the A/C "can" from the fender. This helps with getting the mount in, reintsall them after you have the filter mounted. You should also remove the bolt and nut clip closest to the front of the truck that the A/C "can" bolts to ( You can use a bolt and nut later that passes through the bracket, fender, AS well as the filter mount.
5) I had to remove some material from the chamfered corner because it still rubbed the inner fender.
6) I had to space the A/C "can" off of the original mount 1.5" beacuse it hit the mount and i didn't like it rubbing.
7) Wrap the end of the filter about 10 time with electrical tape because the factory hose is a bit too big.
I forgot to add, that i didn't remove the black metal bracket that the stock box bolt onto, beacuse i didn't feel like filling the four holes is leaves.
I don't know how to post pictures on a tread so just check my gallery
Old Mar 20, 2006 | 11:12 AM
andyr354's Avatar
Another tip:
When I made mine, I used one of these (race car buddy had them laying around) to hold it in at the front. Much easier than reaching around and getting a nut on a bolt. I used aluminum so I could not weld the nut in place.
http://www.speedwaymotors.com/xq/asp...qx/Product.htm
Old Mar 20, 2006 | 11:38 AM
ruquik's Avatar
Actually mine is aluminum, sorry. I used a piece of 1/4" plate the length of the mount and tapped 1/4-20 treads into it.
Old Mar 24, 2006 | 02:42 PM
Old Skool Ram's Avatar
Hey I was wondering where I could get a old smokey mount? If anybody would let me know it would be greatly appreciated!!!!
Old Mar 26, 2006 | 01:38 PM
ruquik's Avatar
Pretty much have to make one up yourself.
Old Mar 26, 2006 | 04:25 PM
Mike E.'s Avatar
I took the plans to a welding shop and they made me one out of aluminum dimond plate for 50.00. Its either your time or money.
Old Mar 30, 2006 | 06:27 AM
Darn! Thats what I thought I was gonna hear, guess im gonna have to get one made somewhere. I appreciate it!
BRUISER
Mar 27, 2009 10:02 AM
M1Lover
Jun 25, 2008 04:46 PM
cootz
Aug 16, 2006 06:18 PM
ViperSBT
Dec 1, 2005 06:16 PM
Tuckerdee
Aug 4, 2005 09:40 AM
