Bedliner Brand Opinions
Old Jun 21, 2014 | 10:25 PM
brcron007's Avatar
Hi Guys, I have just finished sealing the inside of all 4 of the Crew Cab doors for my conversion.
I plan on using a quart of bedliner material in each of the doors to replicate the tar that was sprayed on the inner skins in 84. I think it is/will be better than the thin dynamatt and similar materials. JMO.
I know a few have used a few different brands of the bedliner "Goop"and wanted your opinions on which is the thickest and has the best adhesion ?
Thanks for your input
Old Jun 22, 2014 | 07:27 AM
Thickest and best ?
Pay Linex to do it. That's the thickest and best.
(if you find the right shop, that is)
A good shop will spend a minimum of 3-4 man hours prepping the bed. If they don't, it will peel off in sheets.... or so that's what the local guy pointed out.
Worth every penny I spent and here are the pix to prove it.
https://www.dieseltruckresource.com/...light=bedliner
Old Jun 22, 2014 | 09:03 AM
brcron007's Avatar
Hi NJT, Thanks for the info. But not doing the bed. They did do a super nice job.
I'm soundproofing the inside of the four doors and want to use some of the do it yerself bedliners. A lot of the guys were using the bedliner stuff like Lizard skin and some others to coat their floorpans as sound deadner. Was wondering who had had the best results
Old Jun 22, 2014 | 10:06 AM
aicomp's Avatar
I use Lizard skin for inside sound and heat protection. It looks and feels just like bedliner. Summit Racing carries it.
My $.02
Mike
Old Jun 22, 2014 | 10:11 AM
brcron007's Avatar
Thanks Aicomp, Did it go on thick and stay thick ? Have you had any problems with adhesion ? Thanks
Old Jun 22, 2014 | 12:02 PM
aicomp's Avatar
It goes on just like bedliner and is just as thick. A special undercoating gun is used, and Summit sells it also. It adheres just like bedliner as long as it is put on clean metal. Cleans up with water as long as it is cleaned up before setting. Also, the heat and sound deadening are two different Lizard Skin products.
I have it on my floorpans in the Dodge, my Samurai, and on the engine cover and seat areas of the Motorhome.
Hope this helps,
Mike
Old Jun 22, 2014 | 04:08 PM
brcron007's Avatar
Thanks Aicomp, Appreciate your input/experience
Old Jun 23, 2014 | 08:22 AM
lensguy's Avatar
I have been very pleased with monstaliner.
Old Jun 23, 2014 | 09:44 PM
HMX-1's Avatar
We had a Rhino liner on our '03 when we got it in '07 that was put on by the original owner. It did suffer some UV damage and discoloration, and would peel in small pills (think of how a sweater has those pills of material on them).
Our '06 was Line-X'ed by the original owner and shows no signs of pilling/peeling or UV damage, and once I do some more work to our '08 it'll get Line-X as well.
-Kris
Haulin_in_Dixie
Jul 7, 2023 02:13 PM
Opus
Mar 14, 2011 01:12 PM
jlipskoc
Oct 6, 2009 05:29 AM
4x4not
Sep 6, 2005 12:12 AM
JoeDiesel
26
Sep 21, 2004 05:07 PM
