Battery + IP = no power
Old Dec 16, 2007 | 07:41 PM
77machomopar's Avatar
i was driving down I-78 near Shartlesville Pa. (if you know that section it is rough) my truck just off and would not start. i saw smoke and sparks coming fomr under the hood. here my battery tray bolts snapped off( jsut a little rusty) and the battery positive terminal fell against the top of my IP and melted a good sized hole is the top cover. it is not melted all the way through but the truck doens't semm to have the same power when I started it again and it used to have heavy black smoke at start up then clear right away but now it has no smoke besides blue smoke continusly. Could the fuel cutoff seloniod be fried or is it something worse? The Truck:
1988 W100 Short Bed
1990 Non-IC 727 241 Drivetrain
Old Dec 16, 2007 | 07:49 PM
jrs_dodge_diesel's Avatar
Moved to the 1st gen forum for ya. Most likely get more responses here.
My theory is something may have gotten arc welded or fused together from the large amount of current that flowed though the IP. Might want to tear apart and rebuild it.
Old Dec 16, 2007 | 07:58 PM
Is it leaking fuel? Can you post a pic of the damage?
Old Dec 17, 2007 | 10:38 AM
it is not leaking fuel, but i can not get the top cover off becuase they got fised together. How do i post a pic?
Old Dec 17, 2007 | 02:25 PM
If you have it on your computer you can post it as an attachment to your post.
Use the advanced reply instead of the quick reply, then scroll down to where it says "Additional options" and click on the button that says "Manage attachments".
Old Dec 17, 2007 | 03:20 PM
paccool's Avatar
I'm guessing the fuel cone diaphram is toast from the parts getting fused together. If the diphram is damaged, the AFC is not working. It will run just like it has a valet switch turned on plus have a boost leak.
Old Dec 17, 2007 | 07:20 PM
Yep. A pic would be nice to confirm it.
Old Dec 17, 2007 | 09:24 PM
flashgordon's Avatar
Thanks Dave, Learned something to day
Unfortunately, my pic's are to big to post
Flash.
Old Dec 17, 2007 | 09:33 PM
farmer0_1's Avatar
i love this place. have to put that one in the memory banks. hah.
Old Dec 18, 2007 | 05:50 AM
ill take a pic today and try to load it. Thanks
Rancher99
Apr 18, 2011 09:46 AM
jesussaves
Nov 7, 2010 06:55 AM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
