Bad Door Rubber...Where to find more?
I need the inner and outer window seals for the driver and passenger side of my 91. I also need to make the vent windows stop wistling, and I need the door seals. I don't know if I called everything by the corect name but basically I need all the ruber for driver and passenger door in my truck. Im tired of me and my floor getting wet when it rains. Where can I find some rubber that fits well?
The window vents and the door weatherstripping can all be found at jcwhitney...... i think they have the window vent there too. If you search on here you should be able to find a thread with part numbers or try the sticky.
As far as I know the rubber for the vent windows is no longer available anywhere.
So a wrecker/junkyard would be your best bet there. Mine doesn't leak water, but it does whistle annoyingly so I thought I might try a bead of silicone.
As The Sarge said, JC Whitney is a good place to go. I believe they have a complete kit for both doors. Here's an excellent write-up on how to do it. https://www.dieseltruckresource.com/...d.php?t=152939
So a wrecker/junkyard would be your best bet there. Mine doesn't leak water, but it does whistle annoyingly so I thought I might try a bead of silicone. As The Sarge said, JC Whitney is a good place to go. I believe they have a complete kit for both doors. Here's an excellent write-up on how to do it. https://www.dieseltruckresource.com/...d.php?t=152939
I just did this last weekend. I had purchased the complete kit from JC Whitney 2 years ago. I found the door seal perfect but the window trim leaves a little to be desired. The channel the windows slide into seem to be a little too wide and I got some whistling around the windows. I went to home depot and bought 6 feet of rubbler outdoor weatherstripping when viewed from the side resembled the letter "D" I put the flat part of the "D" into the channel since thats the part that has the sticky backing and lined the inside of all the window grooves. I disappears inside the groove and totally seals the window. I almost have to crack the windows a smidge to shut the door now! For a diesel it's really quiet inside now. I almost don't hear cars that are right next to me on the freeway like I used to.
http://www.retailmenot.com/view/jcwhitney.com
You can find new vent window seals on E-bay, or from JC Whitney. Don't forget to get your on-line coupon if your going to JCW....
Handy little site that one.....
ImpulseHydro
Oct 5, 2007 07:04 PM
I PASS GAS
Aug 21, 2007 09:37 PM
subspd
May 20, 2007 10:15 PM
Chad Layton
14
Aug 28, 2004 01:10 PM
