axle nut help
Old Jul 24, 2011 | 01:52 PM
enydick's Avatar
axle nut help
could i get away with using a single axle nut from a 4x4 to get me by for a day or to or get my truck 12 miles
Old Jul 24, 2011 | 01:58 PM
maybe368's Avatar
While I don't recommend it, my truck had only a single rear type on the front and the little clip from the rear stuck in the cutout in the hub. I asked the original owner about it and he didn't remember. It was like that for at least 20 or 30 k miles before I figured out that it was wrong. It was really confusing trying to find out how to set pre-load set up like that. All that said, it is UNSAFE and should only be like that for a very short time..Mark
Old Jul 24, 2011 | 04:48 PM
BearKiller's Avatar
You need to be a little more clear.
Are you meaning to use this nut on the REAR ??
Do you mean to use a nut FROM THE FRONT on the rear ??
If you are meaning to use a single nut from a double-nut/folding-tooth-washer, then NO, unless you drive three MPH and check it every half-mile.
Old Jul 24, 2011 | 04:52 PM
BearKiller's Avatar
Wink >>> best to do things yourself <<<
While we are on the subject, NEVER take for granted that previous owners/mechanics did things right.
When we dis-assembled the front hubs on the son's truck, we found that some previous somebody had installed shiny brand-new folding-tooth lock-washers between the double-nuts and DIDN'T FOLD A SINGLE TOOTH.
wisconative
May 13, 2013 07:20 AM
Clane
Jun 2, 2012 03:31 PM
APD
Apr 29, 2009 08:47 PM
carte89
Apr 18, 2009 07:25 PM
