Automatic to manual swap question
Old Sep 2, 2011 | 05:26 AM
tjram96's Avatar
I am trying to gather all the parts I need to swap my automatic to a nv4500. I was wondering if the backing plate is the same for the automatic and getrag. Thanks for the help
Old Sep 2, 2011 | 06:08 AM
Onemoparnut's Avatar
If you are talking about the plate on the back of the engine the answer is no. The auto and getrags are different and the nv4500 is a different plate also.
Old Sep 2, 2011 | 07:03 AM
Subliminal's Avatar
Actually, the plate is the same between Getrag and 518. I certainly didn't replace the plate when I did my swap. Now the bellhousing...that's a different story.
Old Sep 2, 2011 | 09:48 AM
Douglas2's Avatar
There are indeed two plates. One for G360 and 518/727, and the other for NV4500/5600 and 47RH/RE. The NV one is thicker and has a different starter mount than the earlier and thinner G360 one. Then there's aftermarket, which alledgedly combines the Gen 2 thickness with Gen 1 starter mounts.
cheers,
Douglas
Old Sep 2, 2011 | 09:56 AM
Subliminal's Avatar
Right...I just said the G360 and 518 were the same. Sheesh!
Old Sep 2, 2011 | 10:22 AM
Falcon1's Avatar
you are correct 360 bell housing bolts to the same as the 518. Simple question too much read into it.
Old Sep 2, 2011 | 10:43 AM
Subliminal's Avatar
Woo Wooo! I win a cookie!
Old Sep 2, 2011 | 10:59 AM
tjram96's Avatar
Thanks for the info guys. I should have been more descriptive. I am using a advance adapters conversion bellhousing, just wanted to make sure I didn't need a different backing plate.
blownsmok97
May 17, 2010 02:40 PM
RollsCoal
Jan 5, 2010 06:35 PM
SWATPARAMEDIC
Oct 19, 2009 03:25 PM
Captain Insane-O
Aug 5, 2005 07:00 PM
Captain Insane-O
Jun 5, 2005 11:15 PM
