Annoying vibration...
Old Oct 24, 2007 | 10:29 AM
G1625S's Avatar
I can feel it in the accelerator pedal and the engine seems louder, kind of boomy in the cab. It happens from 1800-ish RPMs to 2100-ish RPMs. Running 2300 down the highway it's as smooth as silk, no pedal vibration. It's RPM dependant, not speed. Could it be tired injectors that aren't evenly popped? I dunno, but it's annoying. Tell me what to check, fellas
Old Oct 24, 2007 | 01:42 PM
Micaiahfied's Avatar
only under acceleration? or always?
Old Oct 24, 2007 | 02:06 PM
MikeThomas's Avatar
motor mounts?
Old Oct 24, 2007 | 02:27 PM
haloman's Avatar
Lack of Stack?
Maybe your fuel pressure is running low in that range?
Old Oct 24, 2007 | 02:53 PM
G1625S's Avatar
I can feel the vibe in the pedal pretty much all the time (in that RPM range), but it really shines over 10psi
Originally Posted by MikeThomas
motor mounts?
Quite possibe...
Originally Posted by haloman
Lack of Stack?
I'll just let that slide...this time
Ahh, more gauges They're coming.
Old Oct 24, 2007 | 08:31 PM
rlyons's Avatar
Harmonic balancer slipping? They do go bad sometimes.
Old Oct 24, 2007 | 08:35 PM
Boatnik's Avatar
Could the exhaust pipe be hitting the frame?????
Old Oct 25, 2007 | 05:22 AM
G1625S's Avatar
I've looked into the exhaust, but I'll have a closer look for witness marks. Thanks for the suggestions!
Old Oct 25, 2007 | 11:39 AM
Diesel Junkie's Avatar
So we know its Directly tied to engine RPM.
Can you reproduce it with the clutch pushed in? or with the tranny in Neutral?
all of the clutch and 1/2 of the transmission always spin at engine speed when the clutch is out.
Old Oct 25, 2007 | 01:44 PM
kwast's Avatar
hmmmmmm..... i just may have the same symptoms as you...... I'll keep you posted if I find it..
Old Oct 28, 2007 | 06:38 PM
Cowboy_Customs's Avatar
Lack of Stack?
Ahhh but I wont!! Its just got to be that muffler, im tellin ya, your motor is revolting against this horrible horrible censorship. LET IT SPEAK!!
Im going to jump onto the harmonic balancer band wagon. With 440K miles I cant immagine its still in tip top shape.
Check the T-case fluid lately?
Old Nov 1, 2007 | 11:18 PM
HaulinBut's Avatar
Just to clarify.........when you say it is "RPM Dependant", do you mean it happens at that rpm in each gear, or just in top gear? If it is the latter, I would be more suspicious of something in the drive train, whereas if the former, more like possibly the harmonic balancer on the crank.
Old Nov 2, 2007 | 05:49 AM
G1625S's Avatar
It'll do it in every gear. I notice it more in 5th because that's where I do most of my driving.
dodgedsl03
Jan 18, 2007 10:08 PM
SRTchris
Dec 23, 2006 03:16 PM
Hoss
15
Oct 17, 2003 08:33 PM
PADZZ
Mar 7, 2003 10:43 AM
deere nut
Dec 1, 2002 08:09 AM
