alighnment tool
Old 11-25-2010, 01:20 AM
dangina's Avatar
Exclamation alighnment tool
don't know if this is the appropiate place for this but needed ASAP - I'm just doing the nv4500 swap in my 90 diesel and i need the alignment tool to install the clutch/flywheel. Where can I get one without buying the entire clutch kit? anyone have one for sale? I can pay paypal. I've went to all the local dealerships and auto parts stores and no one sells it seperate without buying the entire kit. I would even consider just buying the clutch if it came with tool then it would at least be half the cost - I've already been set back with this swap since the getrag died - best place to reach me is at:
y2kdano@gmail.com
Thanks DTR!
Old 11-25-2010, 05:30 AM
infidel's Avatar
Use an old input shaft.
Old 11-25-2010, 08:04 AM
You can buy them seperately off advance auto if i remember right.
I'll look for the one i have, if i have it just cover shipping to and from and it's yours..I'd like it back for the future.
Old 11-25-2010, 08:47 AM
sooty's Avatar
tool loan
autozone and similar auto parts retailers loan tools, also rental yards
Old 11-25-2010, 09:52 AM
CaptainChrysler's Avatar
You could just pull the input out of the NV4500 and use it. There are 4 bolts that hold it in. There is a little caged needle bearing and a thrust bearing in there. Just put the bearings back and re-seal it with silicone when you are done.
It is possible to eyeball it too. Just get where you can look it straight on and center the disk up.
If you have a helper, they can hold the clutch down. (after the bellhousing is bolted up tight) so you can wiggle the disk around and line it up.
Happy Thanksgiving!
Old 11-25-2010, 01:07 PM
dangina's Avatar
lol its my first truck let alone diesel if it were cars no problem!
Happy Thanksgiving!
I might use this suggestion if I can't find one in time - I'm back to work here tommorrow so I cant finish working on it until next week
thanks for the suggestions!
Old 11-25-2010, 09:43 PM
MARF75's Avatar
Dude...your name is great!
Old 11-25-2010, 10:12 PM
Best Paint (Getrag category)
pulltilbroke's Avatar
I don't think I've ever used the alignment tool, I always done like everyone else does and use an old input.
Old 11-25-2010, 11:56 PM
dangina's Avatar
you can thank the guys I work with for that one!
Old 11-25-2010, 11:58 PM
Mark Nixon's Avatar
Your old Getrag input would work.
Just use an angle grinder and whack it behind the splines.
Mark.
Old 11-27-2010, 02:22 PM
dangina's Avatar
Mark.
This is the best Idea - I can't believe I didn't think of it earlier, especially when I'm gonna ditch the getrag anyways..
Mkinner
09-21-2010 07:57 PM
zspear1
01-02-2006 08:17 AM
SBishop
02-14-2004 05:21 PM
Redleg
12-27-2002 09:25 AM
yz
10-16-2002 09:14 AM
Quick Reply: alighnment tool
