Air intake pipe
Old Sep 14, 2004 | 11:00 AM
Nuttymopar's Avatar
Air intake pipe
So, I have the BHAF & the 16 cm2 turbo. But I am still using the stock air pipe?? that goes between them. What does every one use to make a straight shot from filter to turbo? I know I need to pick up 2 45 degree elbows to complete the package. Is it safe to use 4" PVC tubing? Should it be metal? Could I use stove pipe stuff? I can think of several things to use that are 4" in size but what is preferred?
Thanks.
Old Sep 14, 2004 | 11:12 AM
carl20320's Avatar
I am using 4" aluminum tubing from here . Price is right and they get it to you fast. You can also get the elbows and clamps ehre as well.
Carl
Old Sep 14, 2004 | 11:13 AM
jiMMyCTD's Avatar
see my memebers pics for my set up. everythign came from an online vendor air flow systems i think.
i got a 1 ft piece of their 4 inch alum tubing, its thinner and connects easier to the elbows as well.
jiMMy
Old Sep 14, 2004 | 11:19 AM
Nuttymopar's Avatar
Thanks to both. I am out surfing right now checking out there site. Looks like that will be a done deal. Thanks again. Straighter flow should equal better HP. OK, maybe only a hair better.... but better.
Old Sep 14, 2004 | 11:42 AM
jiMMyCTD's Avatar
sounds better and flows more air for sure. as for HP probably not to noticable but your temps will like you better!
jIMMy
Old Sep 14, 2004 | 12:16 PM
Nuttymopar's Avatar
Let me ask this question then. Should I go with the 4" piping (need to measure for length) all the way through it from start to finish or should I get the 5" piping and some how shrink it down to the turbo size? I assume 5" would possibly give me a slight more volume and shrinking it down would increase the speed of the air as it compresses which might help with boost?? Not sure just thinking about it. Need to take measurements of both my BHAF and stock filter and also turbo size inlet.
Old Sep 14, 2004 | 03:35 PM
I don't think changing sizes would be productive.
The best way to do this setup is to put a really short piece of pipe (like 3 inches long) between the BHAF and the elbow because the BHAF was designed to clamp over a 4" pipe. The elbow butts up against the BHAF but doesn't clamp over it when set up this way. You can stretch the elbow to fit over the BHAF but there's not much room for the clamp, it's better to do it the way I've described.
You need two 4" 45 degree boots, 5 clamps, and about a foot and a half of 4" pipe. Aluminum tubing looks cool, but exhaust pipe or PVC will do fine too.
Old Sep 14, 2004 | 03:46 PM
Nuttymopar's Avatar
Thanks Dave. I have noticed that the stock pipe doesn't clamp the best over the BHAF but it does do it. Just crank down rather good on the clamp. But I like your idea better.
Jimmyctd: I like your BHAF mount.. LOL. Trying to save some weight using Cloths Line. Good choice.
Taquache
21
Jun 24, 2012 03:11 PM
herb
Jul 18, 2008 08:25 AM
Dodgewincity
13
Jan 19, 2008 05:41 AM
D45
17
Dec 6, 2007 01:52 PM
BA05'CTD
Jan 7, 2007 03:08 PM
