Aftermarket Injectors for First Gen
Originally Posted by Begle1
Oh boy, I have to flaunt my ignorance on that one...
Care to explain the theory behind why that is? More fuel equals more timing? I didn't know that they were relative...
Thanks.
Thanks.
The POD's are a lousy injector design. Only 4 nozzles with a "sac" that holds fuel after the main injection event, almost like a stock injector that's dribbling. Because of the design, they need more timing to have a chance at burning all the fuel they dump in.
"If they're so lousy, why do we use them?"
Because they are cheap and brutally effective.
More fuel does not necessarily mean that you need more timing.
DD4's make about 15 HP more than POD's for a little under double the price. AFAIK, they are a custom tip on rebuilt stockers. Talk to PDR about them.
Any of the custom injector makers can make you whatever you want provided you are willing to pay them for it. You are limited only by your budget.
The 12 valve 2nd gen injectors will not fit up to our lines and have too high a pop-off pressure. You have to call and ask for the 1st gen ones.
Just the typical 1/8" timing bump will make it run good, but you will be severely overfu.. I mean under-turboed.
You would need more air even with stock pump settings, those are some big injectors.
Yes 1st gen ones. It's to bad that Piers doesn't have their other options for us clearly grouped .[shoot the webmaster] We are planning on their 35/40 ported to their 16cm housing the goal is a bout 250 hp with min pump adj and smoke[pods
Another option is the Bully Dog +50s. They give about + 25 in a non I/C engine.
I'm running them and they don't smoke at all at idle and I can get the same mileage as I did with the stockers if I keep my foot out of it. (but I don't).
Jay
Jay
Jay
Jay
I haven't checked in a while, but the Bully Dogs used to be available thru several sources...they were a little pricey compared to PODs...I think they were in the $600 range.
I lucked and got mine used ( and a greatly reduced price) from a fellow TDR member who put 3000 miles on them.
I'll surf around later today and see if I can find them.
Jay
Jay
penguinman
May 7, 2012 05:02 AM
Trebor
Aug 5, 2009 10:54 AM
cLAYH
ABDTR #5
25
Jul 18, 2009 08:07 PM
