AFC Spring
Old Jun 24, 2005 | 08:47 PM
fearthedeere's Avatar
Now im gonna have nitemares thanx wanna
Old Jun 24, 2005 | 08:49 PM
Any leads on where i can get one of those free or cheap 12cm housings?
Check the classifieds here and on TDR, also look on Ebay. I've seen them go as low as $15 on Ebay, and the one that started me on the downhill slide was free.
Old Jun 24, 2005 | 08:55 PM
Don't be too paranoid about it, just get a 60 psi gauge on there so you know where you stand. Like I said, mine stood 50 psi when I was racing a Camaro with a turbo under the back bumper. I was pulling away when I glanced at the boost gauge, too.
It could be maxing out at 33 psi, who can tell? If you have an oil pressure gauge laying around, throw it on there instead. Pressure is pressure, the gauge doesn't need to say "boost" on it.
Old Jun 24, 2005 | 09:13 PM
pwrtripls1's Avatar
Your truck is fast enough to pull on a Camaro!!!!!!!!!!!!!
Thats where i want to be.
Old Jun 24, 2005 | 10:40 PM
How u wastegate the manifold?
Old Jun 25, 2005 | 02:03 AM
Bushy's Avatar
Patron Saint of 1st gens
The hybrid 35's are a pretty tough unit....in my case I've run mine to pretty much ludicrous levels and it still keeps on spinnin'.....
At this point I've run as high as 47psi boost at approx 1800*F....I'm not saying it'll take that forever but it has taken a beating and kept on hangin in there for me....
I'm also using a 16cm on the hot end...it performs very well for the way I've got my fueling set up...
I've also run a non-gated 14cm and while it was a rocket to spoolup it was just plain "thermonuclear" in the heat department at my fueling levels,so, I went to the 16cm and it works pretty well.
I just need twins to burn the fuel I've got...mind you, the water/meth really helps alot to..
pb...
Old Jun 25, 2005 | 05:59 AM
This was in 5th gear at over 60 mph. That's the torque talkin', baby. I wouldn't have had a snowball's chance in hell of beating him off the line.
He passed me, I saw the turbo, I pulled alongside and gave a thumbs up and it was on! I'd like to try that guy again now that the boost is under control.
Old Jun 25, 2005 | 06:01 AM
You have to drill a big hole near the turbo flange and weld a wastegate flange onto the manifold. Then you can use a ricer wastegate.
royta
Feb 15, 2005 10:15 PM
halerazor
14
Jan 18, 2005 05:28 PM
boughtadodge
Jan 21, 2003 10:03 AM
boehunter49
Dec 13, 2002 07:10 PM
Dusty 96
Nov 5, 2002 01:45 AM
