ac condenser for a trans cooler??
Old May 6, 2009 | 09:35 PM
STACKED's Avatar
Since i have major issues with my tranny temps, i was thinking or using an ac condenser for a tranny cooler. the lines into and out on the one im looking at trying are 1/2" so What do yall think?
Old May 6, 2009 | 09:46 PM
archer2's Avatar
I don't see why not, I've used one for years on my 727. What application uses 1/2 in and out?
Old May 6, 2009 | 09:50 PM
STACKED's Avatar
its one out of a 90s chevy half ton.
Old May 6, 2009 | 10:49 PM
HotRodTodd's Avatar
I used to have a 74 1 ton 4x4 Maxiwagon, it had a condenser for a tranny cooler on it for about 20 years, it worked fine.
Old May 7, 2009 | 01:22 PM
STACKED's Avatar
Right now i have the factory cooler and i took out the heat exchanger and put a 6 row cooler in. Do you think it would help putting the condenser in.
Old May 7, 2009 | 04:14 PM
archer2's Avatar
I guess it would depend on how your current setup is handling the temps. You should probably put a gauge in there and see what you have.
Old May 7, 2009 | 11:07 PM
STACKED's Avatar
I have a gauge it sits on about 250 most of the time. It cools down to about 200 when I cruise at 40 mph for a while but it is normally always over 200
Old May 8, 2009 | 08:00 AM
archer2's Avatar
Put the condenser in, those temps are awful high. Where is the temp sender located?
Old May 8, 2009 | 12:07 PM
STACKED's Avatar
It's in the hot line spot.
Old May 8, 2009 | 12:55 PM
klx650a2's Avatar
Wow, those temps are REALLY high. I'd be checking the fluid for burnt smell, etc as I heard the atf+4 breaks doing at 250ish...
Old May 8, 2009 | 01:05 PM
Greed 93's Avatar
Is that towing temp if so how much weight ? if not towing you have alot more to worry about than a cooler
Old May 8, 2009 | 02:26 PM
Thats weird.
The shift kit is supposed to cool things down.
Is it low on fluid? IS it the correct length dipstick?
Old May 8, 2009 | 09:03 PM
STACKED's Avatar
Thats not towing or anything and to tell y'all the truth I have only had the truck a year or so but when we got the truck the tranny was suppose to have just been serviced. I could tell the tranny was slipping so I checked it and it said full but I noticed on the dip stick it said check in neutral so I did and it was 4 quarts low. I don't know how long they had been checking it in park so I'm not sure .
Old May 10, 2009 | 02:41 PM
NO_SPRK's Avatar
I see some trans pan companies tap them for temp sensors but I would think putting the temp sensor right between the trans and cooler outlet line would be perfect. Right now mine is in the side of the trans in a small hump. I forget what its called but my trans guy said its not the greatest spot for it
Old May 10, 2009 | 09:53 PM
mjozefow's Avatar
I'm no expert but it seems that the root of the problem is not your cooler. It should run a lot lower than that. I'd look for the root issue, not a way to compensate. My .02
