93 problems
Old Jan 8, 2005 | 11:22 PM
dodgeman01's Avatar
93 problems
I have a buddy with a 93 Dodge 1ton. his truck runs great and then all of a sudden it will lose power and RPM's it gets really quiet and you can barley hear the truck running. if you just mash the throttle it will come back alive like nothing happend. there is no speed or reason for it, it does it when ever it wants. any ideas guys? thanks
DM01
Old Jan 9, 2005 | 04:15 AM
frostie's Avatar
I would check the fuel transfer pump pressure first, if it is OK when the failure occurs than I would be thinking about the injection pump. It may be as simple as a problem with the shutdown solenoid.
By the way, where have you been Dodgeman
Good luck
Frosty
Old Jan 9, 2005 | 08:03 AM
uncleroty's Avatar
When my shutdown solenoid was not getting sufficient current, that is what my truck did. Check the connections first, and see what the battery/charging condition is like. A wonky voltage regulator and a bad battery could theoretically give you the same troubles I suppose. Mine was just the connection though.
Let's hope it's just that. We all know what injector pumps cost.
Good luck with it.
Old Jan 10, 2005 | 11:23 AM
dodgeman01's Avatar
Thats what I thought. I played around with the wires today one was loose so I fixed it that seemed to help out a lot but it still does it. The truck have 300K on the engine and 500k on the truck so no telling what has gone wrong.
Frostie
whats up man I know its been a while. I've been really busy and also for a while there my computer was down so other than that every things been going good. Got a lot of new parts for my truck so next year sled pulling will be really fun
Hope everythings been good with you
thanks and later guys
DM01
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
