93 dually rear disc brakes from 05
Old Jan 30, 2006 | 08:02 AM
scottmn1's Avatar
I have a 93 D350 CTD with, of course, rear drum brakes. I have ran across a complete rear end assy from a 2005 1 ton Dodge dually that was removed because it had a bent axle housing. However, all of the rear disc brakes and related parts are there, intact, and undamaged. My question is, will these disc brakes from the 05 bolt up to my 93 axle housing? Of course a different master cylinder will be needed. How much better are the disc brakes over the drum brakes?
Thanks, Scott
Last edited by scottmn1; Jan 30, 2006 at 01:25 PM. Reason: meant axle housing, not axle shaft
Old Jan 30, 2006 | 08:43 AM
lovemysan's Avatar
I don't know if those parts will bolt in, but I do know that the master cylinder will not correctly deliver fluid to rear disc brakes. Drum and disc require different pressure.
Old Jan 30, 2006 | 04:34 PM
The '05 uses an AAM axle, not a Dana. Not going to be a bolt-on.
1992 Renegade
Oct 11, 2014 03:29 PM
2500CTD
Oct 19, 2010 07:10 PM
jimbo486
Sep 29, 2009 04:07 PM
ShawnQ
Jan 12, 2006 08:09 PM
kwhite4
May 9, 2005 03:22 PM
