93 250 charging trouble
I am new to this site and I am having charging problems with my 93 250.I was wondering if the regulator could be repaired or is my only choice reman or new from the dealer? Any info greatly appreciated! Thanks
Re:93 250 charging trouble
Welcome...
The regulator is part of the PCM on the engine. Check your crank sensor for operation. If the computer doesn't know the engine is running it won't engage the alternator or A/C systems as well as many of the automatic transmission stuff.
Search crank sensor and you will find many many posts on this..
J-eh
J-eh
Seems like I remember reading that the pcm controlls a relay to operate the alternator. It wont turn it on without a signal from the crank sensor. So you could have a bad crank sensor, bad wiring, bad pcm. bad relay or bad alternator.
Thanks for all the input! I believe I have figured out my problem! I have a bad crank sensor. I disconnected the sensor and momentarily touched a jumper between the 5 volt reference wire and the signal return wire and it tried to charge but it cut back off so I think it would be safe to say that my regulator is ok. I could brush the jumper back and forth and it would charge normally. This also explains why my AC doesn't work and why I was experiencing the stubborn OD shift that some of the guys were talking about.I wonder if this could cause the cruise control not to work properly? I called Advance Auto Parts and they said they only had a listing for a manual trans application. I wonder if it would make a difference?Anyway,you guys have really enlightened me on this problem and I really appreciate allthe help!Any more input on this will be greatly accepted! Thanks again! ;D
