92 diesel that idles full throttle ????
Old Dec 16, 2005 | 10:14 PM
national's Avatar
When you start it is is wide open throttle..linkage is not stuck or anything that we can tell..an injection pump had been put on a lil while back & all was ok but idled a lil low & the guy that installed it was going out of buisness but he turned a screw on the pump( i think) somewhere & all he said was you didnt see me do that..what ever that meant & then a few days later its idling very high..any ideas as to what this might be?
Thanks,Brian
Old Dec 16, 2005 | 10:42 PM
loch's Avatar
I would think what has happened, he turned the fuel screw, if turned to far it can run away. Try turning it in a turn.
Old Dec 16, 2005 | 11:13 PM
national's Avatar
Thanks for the quick reply..where is the fuel screw located? any pics or ideas how to make sure im at the right screw?
Thansk again,Brian
Old Dec 17, 2005 | 06:54 AM
G1625S's Avatar
Hi National, and welcome to DTR! The adjustment you're after is the full fuel screw. It will be facing the firewall about 1/3 the way down the pump. It has nothing to do with the two throttle linkage stop screws, it's a whole separate deal. You'll likely need a long flat blade screwdriver to turn it and a 1/2'' (or 13mm) wrench to break the stopnut loose. Back the screw out 1/2 turn at a time, starting the engine afer each try, untill it idles. Let me see if I can find some pics for you...
greg
Old Dec 17, 2005 | 08:26 AM
lovemysan's Avatar
If you can't get your screw driver in there, I always use a 6mm closed end wrench on it.
With a runaway wouldn't you turn the screw out to stop a runaway.
Old Dec 17, 2005 | 08:45 AM
G1625S's Avatar
''With a runaway wouldn't you turn the screw out to stop a runaway.''
yes.
Old Dec 17, 2005 | 01:18 PM
loch's Avatar
Oops im sorry, it is turned out to lesseon the fuel.
Old Feb 10, 2006 | 12:45 AM
national's Avatar
Well that wasnt the problem..actually didnt make any difference..have been told it is something inside broke..like the main shaft in the pump..have to pull the pump to see I guess..
Thanks,Brian
Old Feb 10, 2006 | 04:10 AM
timb's Avatar
I think these trucks had a problem way back with the fuel pin breaking or sumpin like dat. I think that I would check my fuel pin first though.and welcome to the site of the slippery slope.
Old Feb 10, 2006 | 08:17 AM
92DIESEL's Avatar
Isnt there something inside our pumps that produces full fuel until it starts, that's why we start so fast. Maybe it is sticking? I know PB or wannadiesel know what I'm talking about.
Oh, and welcome to the site,
Michael
PS, at first I thought this thread was about me
Old Feb 10, 2006 | 06:18 PM
You're so vain.
Old Feb 10, 2006 | 07:16 PM
rlyons's Avatar
Take your VIN number to a Dodge dealer and see if your truck was involved in the recall to replace the injection pumps due to a runaway problem. There are still a few out there that were missed. Here is a link to some info on the recall http://dodgeram.info/tsb/recalls/605.htm
Old Feb 11, 2006 | 08:35 AM
92DIESEL's Avatar
You're so vain.
I know
Onemoparnut
Aug 19, 2013 08:11 PM
Mallard
Apr 9, 2007 12:59 AM
ramduck
Jul 5, 2005 07:21 PM
seagravedriver
May 30, 2004 12:50 PM
j
Nov 14, 2003 09:38 PM
