91.5 and 93 motor differences
Old Aug 15, 2007 | 08:37 AM
timb's Avatar
I made my own gasket for my turbo drain, so I can't say yes or no to the instant gasket. There is a cover with two bolts in it right above the transmission cooler on the passenger side of the bell housing adapter. Look right below the turbo and you will find this cover. this is where you install the torque converter bolts through. Just turn the engine over and the bolts will line up with the hole.
Old Aug 15, 2007 | 08:54 AM
Ace's Avatar
Ace
The output side of the oil ports on the turbo is not under much pressure, so you could probably get away with it, but a gasket would be recommended.
Old Aug 15, 2007 | 09:13 AM
ryan10's Avatar
Ok, thanks. i know where the torque converter bolts go, just wondering if there was an easy way to get them in?
thanks.
Old Aug 15, 2007 | 06:03 PM
ryan10's Avatar
ok, well a little update. i got the motor in, and the motor mounts and tranny lined up. gonna bolt up and plug everything in tomorrow. should be back in action tomorrow night
Old Aug 15, 2007 | 06:26 PM
I would use a real gasket there. If you don't have time, use a very thin bead, you don't want chunks of RTV floating in the oil.
Old Aug 15, 2007 | 06:35 PM
ryan10's Avatar
ok thanks. any tips on getting the Torque converter bolts in?
Old Aug 15, 2007 | 08:59 PM
wingnuts0nr's Avatar
Originally Posted by ryan10
sorry, the oil tube to the turbo. a little update both motors are out and the new one is going in tomorrow. think i can have everything done tomorrow?
So, can i use instant gasket on the oil tube to the turbo? also, any advice on how to get the torque converter bolts back in?
thanks.
There is a little cover on the right side of the engine (pilots point of view) that is about 2" oval shaped remove it and have somebody turn the crank while you use an extension and socket to install bolts... once you get started it goes really quick, I Just put a suncoast T/C in my 91.5 last week so still pretty fresh, however i still need to put the cover back on was to ready to see how she ran after the T/C
Old Aug 16, 2007 | 07:56 AM
Ace's Avatar
Ace
...you don't want chunks of RTV floating in the oil.
Exactly. If you do decide to go the sillycone route, make sure you tighten the bolts only finget tight and wait at least overnight before tightening to aviod squeezing out the excess. It'll seal better that way too.
MoparTyson
Jun 18, 2014 10:48 PM
ryan10
Aug 15, 2007 05:20 PM
ryan10
Aug 10, 2007 09:38 PM
Common
May 9, 2007 12:11 AM
coupdetat
Feb 17, 2007 12:52 AM
