motor mount differences???
Are the metal motor mount stands the same for a 2wd as a 4wd? I've got a 95 P-pump motor I'm thinking of putting in my 85 w350 crew and need to figure which mounts to use. I've searched the inter webs and have not come up with an answer.
If you are talking about the U shaped part between the plate that bolted to the side of the block and the motor mount. they are the same between 2WD and 4WD. But the right one is shorter than the left. The reason I know is I made my own crossmember and it takes two right side parts. I can take som pictures if it will help.
Are the plates that bolt to the engine interchangeable? they look like they are. that would make it easy.
Mopar1973
Feb 1, 2014 09:31 AM
chw
Dec 25, 2006 04:30 PM
