91.5 and 93 motor differences
Old Aug 11, 2007 | 06:55 AM
ryan10's Avatar
Hi, i found a parts truck with a 91.5 intercooled motor. will this swap right in or will i need to change the IP and stuff like that?
Old Aug 11, 2007 | 08:13 AM
timb's Avatar
Exact same animal. Swap away my friend.
Old Aug 11, 2007 | 10:19 AM
You will need to swap on the crank sensor (and the damper if there aren't notches in the '91.5 unit) so the PCM will get the hint that the engine is running. Otherwise you get no charging system, A/C, cruise, etc.
Old Aug 11, 2007 | 09:27 PM
ryan10's Avatar
well, the truck is a 93, so the swap should just be a direct bolt in correct? also, any difference in flywheel between a 2wd and a 4x4?
Thanks.
also, does anybody know what gears were offered in the rear end of a 93 2wd? im hoping it has 3.55s as my rear end has a lot of slack in it.
thanks.
Old Aug 11, 2007 | 09:36 PM
mwlu711's Avatar
fly wheel should be the same.
Old Aug 11, 2007 | 09:38 PM
rbrettctd's Avatar
3.54s and 4.10s were both offered. Could be either.
Old Aug 12, 2007 | 12:45 PM
ryan10's Avatar
ok, well i bought the truck and it turned out to be a 92. The rear end is a 3.54 and it has overdrive. will this motor swap right in without modifications.
Old Aug 12, 2007 | 05:22 PM
Yes.
My truck has a '92 motor.
Old Aug 12, 2007 | 09:32 PM
ryan10's Avatar
Ok, well im gonna try and finish up this swap tomorrow. just gotta undo the motor mouts on the parts truck and yank the motor and set it in the new truck and start putting it all back together.
any tips on putting the torque converter bolts back in?
also, my new motor that i got is stock and man what a dog, cant wait to start bombing this one.
Old Aug 13, 2007 | 01:31 PM
ryan10's Avatar
Ok, well everything is undone, but i cant get the motor to lift out. i have the chain attatched to the hook on the front left and the hook on the back right. the motor hits the cab and i cant get enough clearance to get the oil pan over the crossmember. any ideas?
Old Aug 13, 2007 | 02:27 PM
Sounds like you are gonna have to pick it back end first. Change where you are lifting on the chain.
Old Aug 13, 2007 | 03:29 PM
ryan10's Avatar
well i tried to pull the motor with unbolting the torque converter as i always do with my chevys. i had to unbolt the TQ and it slid right out. should have the truck up and running tomorrow night if all goes as it should.
Old Aug 14, 2007 | 09:36 AM
ryan10's Avatar
Ok, for the oil tube, can i use instant gasket to make a gasket for it or no?
thanks.
Old Aug 14, 2007 | 03:24 PM
Which oil tube?
Old Aug 14, 2007 | 08:21 PM
ryan10's Avatar
sorry, the oil tube to the turbo. a little update both motors are out and the new one is going in tomorrow. think i can have everything done tomorrow?
So, can i use instant gasket on the oil tube to the turbo? also, any advice on how to get the torque converter bolts back in?
thanks.
