89-93 Dodge
Old Jul 28, 2010 | 09:35 AM
Jasonbailey's Avatar
Question 89-93 Dodge
Ok, so the 89-93 Dodge has the Cummins I6. Thats 160 HP and a very impressive 400 Ft Lbs of torque. Without doing an engine swap for a 12 valve or 24 valve Cummins and keeping the same engine, how do I get more horsepower and keep the same torque?
Old Jul 28, 2010 | 09:41 AM
BC847's Avatar
1st Generation Admin
The 89~93 Cummins is a 12 valve just like the later 2nd gens. The injection pump is the major difference.
Most who increase the horsepower also see an increase in torque. There's not really a way around that.
How fast do you want to go? What do you intend to do with the truck? Work? Race?
Old Jul 28, 2010 | 10:45 AM
dieselJon's Avatar
Torque@RPM=HP
The more torque over the RPM band (not getting into power band debates) is more HP. If you look at gas engines, torque usually comes in sooner the HP. They have more of a RPM band to make up for the loss HP in the lower RPM's.
Old Jul 28, 2010 | 11:06 AM
Read the "Sticky" at the top of the 1st gen board
https://www.dieseltruckresource.com/...t-t102027.html
Scroll down to "performance"
Turning up the pump is a good place to start, then air flow mods, then injectors, then turbo, then headwork/stud head after you blow the head gasket.
Oh and somewhere in the early stages in there, you'll need a better torque converer if you have an auto or a good clutch if you have a 5spd. you'll slip the stock one
Old Jul 28, 2010 | 11:16 AM
CaptainChrysler's Avatar
Cylinder pressure = torque.
Old Jul 28, 2010 | 11:28 AM
petrecca8's Avatar
One of the easiest things for a little extra acceleration is to turn the fuel pin cone around so the deeper side is facing forward. And then just adjust the pump like it shows in the sticky.
Old Jul 28, 2010 | 12:22 PM
I drive an '02 model and I'm used to my 235HP, the added torque will be great though. I did figure that anything I do will probably add more torque as well which is fine.
Old Jul 28, 2010 | 06:34 PM
BC847's Avatar
I drive an '93 model and I'm used to my 447HP, the added torque is great though.
Old Jul 28, 2010 | 06:37 PM
brag brag brag.....
Old Jul 28, 2010 | 07:18 PM
Onemoparnut's Avatar
Well ok lol... haha
Old Jul 30, 2010 | 07:44 AM
NE frmhnd's Avatar
I like mine where it is. Once I get to 35 it's shifted into drive, roll into it and away I go. Even with less horse I think these have a weight advantage that makes up for a good part of the lower power.
1stgenatheart
Oct 19, 2009 06:33 AM
joebishop23
Oct 29, 2007 10:19 AM
wreedCTD
27
Sep 30, 2007 09:52 PM
96_12V
Jul 17, 2007 07:03 PM
texasredrider
30
Nov 14, 2004 10:35 PM
