518 in a 1990?
Old Dec 18, 2007 | 07:31 PM
Bruce M's Avatar
518 in a 1990?
When my 727 gets tired, how is it installing a 518 with my existing 3.07 rear end having just taken apart a 91.5 donor? With the 727 I run 2050rpm at 60mph.
Very seldom do I run above 65mph. Would like to run about 1800rpm on the freeway at about 70mph. Any problem with the switch?
Old Dec 19, 2007 | 06:59 PM
If you have all the pieces it wouldn't be too bad a job. If you want it to work "factory" you will have to swap in the baby PCM to run the OD. It should work OK with just the power, ground, VSS, and TPS inputs. Keep the old brain box on the firewall to run the WTS and WIF lights and the KSB.
SmokinFive9 4x4
Sep 27, 2005 08:16 AM
clarkoh
Aug 19, 2005 09:24 PM
Rammer64
Apr 10, 2005 10:15 AM
moparguy
Jan 9, 2005 09:43 AM
Graeme
Feb 5, 2004 04:47 PM
