4x4 Conversion for a d250 2wd
Old Jan 28, 2008 | 11:53 PM
BurnoilPlease's Avatar
I have a D 250 which has been in the family since 91 and i adore it, Its a great truck, it has power, looks and versatility.... Until you get into moisture, a field or mud, its completely helpless... I was wanting to know i could convert it from 2wd to 4wd. Is it a pain in the you know what. I refuse to let go of this truck and want i want it to stay in the family for as long as it's got wheels.
Winters like this are killing me!
I was parked for 5 minutes and i almost had to pull myself back to the house with the tractor.
Any help is greatly appreciated, Thanks and stay safe out there.
Old Jan 29, 2008 | 12:27 AM
C/PRD/'s Avatar
Here> http://www.cumminsforum.com/forum/89...ere-we-go.html
Edit: WELCOME!!
Old Jan 29, 2008 | 07:51 AM
pwrtripls1's Avatar
Its not hard to find a Dana 60 front axle, there all over. Then find you a 205 transfer case, front drive shaft, have the rear shaft shortened, remove all the coil front suspention, weld on some leaf spring mounts, and tie in your steering how ever required.
Sure sounds easy when you say it like that huh? lol If you have a good welder and plenty of metal and all the parts then the whole ordeal should take 3-4 days of hard work.
IMO though, buy a cheap 4x4 winter beater to take the salt abuse and save the nice truck for the rest of the year. When I was in Maine I bought a w350 4x4 cummins plow truck for $500, spent $20 fixing it and drove it over a year. Then I put it in UncleHenry's and sold it for $2500 in 30 minutes. lol
Old Jan 29, 2008 | 04:10 PM
GO OVRIT's Avatar
Its not hard if you have some fab skills. The parts aren't hard to find either...just pricey. The easiest way to do it would be to find a donor vehicle to get everything off of. (parts and measurements)
Old Jan 29, 2008 | 04:20 PM
Ezra's Avatar
Unclehenry"s...I almost forgot about that,I loved that when I lived in Maine.
Old Jan 29, 2008 | 05:00 PM
SuperiorRam's Avatar
try a power-lock first one wheel to two will make a world of differnce that is basicly what a conversion is any way one in front one in back, try two in back first it's a lot cheaper and a lot easier???
Old Jan 29, 2008 | 05:05 PM
i have done it a couple of times on these model trucks and it takes a lot of time money and skill
p.s. you basicly need a front frame section because the front 3 yes three crossmembers are diffrent than 2wd trucks then the front and rear spring hangers as well as the steering box bracket and draglink and so on and so on
Old Jan 29, 2008 | 05:52 PM
Thanks everyone for your suggestions. I think i might just go for a posi rear end... that way i wont get stuck in dry grass any more during hay season.
Old Jan 29, 2008 | 06:20 PM
pwrtripls1's Avatar
Better get ready to put 1,500lbs in the bed, posi is worthless when all the weight is over the front. Still better to have a wheel pulling from the front where the weight is.
Old Jan 29, 2008 | 06:39 PM
G1625S's Avatar
2k lbs in the bed is still cheaper than a 4x4 conversion
Old Jan 29, 2008 | 08:40 PM
Yea, i should just keep it loaded with hay all year around.
CarBizIndio
Jun 9, 2014 01:03 AM
rcts
Nov 21, 2009 11:29 AM
dzl_damon
May 27, 2008 03:10 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
TexasHardcore
Aug 29, 2004 12:20 AM
