4wd leaf spring (FRAME) Bushings
A dealer can get them. I don't have the numbers anymore. Price was around $6. each. You need 4 each.
Those bushings are only listed in the frame section of the dealer computer. If they look in the front suspension section. It does not show them.
Sweet. Takes the guess work out of trying to figure out how to do that. Thank you for your service to 1st Gen owners everywhere.
In summary... hit it with a torch, make the center ferule for the inner and outer frame bushings pop out (which will be molten hot, land in your eye socket and burn a hole to your brain), then the inner and outer frame bushing halves can be knocked out with a hammer? ....sort of trying to line things up in my simple mind, step one, step two...
And the new bushings can either be tapped in with a hammer and socket, or tightened in with a carriage bolt and a socket.
Think I got it.
Think I got it.
Phillip,
Inflation has affected your pricing
They sell for $ 13.20 at most dealerships. I tried buying them locally and the nasty woman behind the counter wanted $38 each!
I told her to go.....
Part # 2653700 Check your dealerships. Your mileage may vary
Think I got it.
Think I got it.
The bushing half outer shells are hit out with a long skinny punch from the other sides. Not as easy as it may sound, as they're really in there. It's easiest if you can get one out, then the other just pops out because you can be in direct line with the outer shell with your punch or drift. A air chisel may be best.
carriage bolt and a couple sockets 1 1/8" and a 1 3/8" sockets seemed to work best. The smaller of the two goes on the outer rim of the new bushing, and the other one is on the head side of the carriage bolt and rests against the outer frame. I just tapped in the outer ones, as it was easy to do.
T.
Ask if the person is on commision. If he is find another dealer.
List price was $8 when I bought mine. I walked out the door at $6. I have delt with this dealer for over a decade. I am one of the few 1st gener's that can call a dealer and order without being there in person. (If I think they can find the correct part without me leading them threw the computer). Plus I get a discount.
smokinram99
Feb 27, 2008 01:42 PM
95black2615
Dec 20, 2006 06:37 PM
although I woulda grabbed a torque n fire extinguisher right away n torqued the f-ers out.
