tuning for fuel mileage
Old Jun 5, 2012 | 06:16 AM
oilcan64's Avatar
wanna tune it for fuel mileage, so far its all stock except for a hx35 with asa intake and 4" straight exhaust. ive heard that timing helps out, would i be better off with an 1/8 bump or the m&h timing spacer? i have the 366 spring but havent put it in yet too. im assuming leaving the stock fuel pin in would help too. any suggestions? thanks all!
Old Jun 5, 2012 | 11:13 AM
cougar's Avatar
It's not about tuning, it's about your right foot. With all the performance mods I've done to my 91, the mileage remains 18-21. Other than a timing bump and better atomizing injectors, there is nothing more you can do to the engine. And those 2 items will only improve your mileage slightly. You can do fuel substitutions to reduce $ per mile such as WMO, WVO, even water injection or propane as an alternative. You can't change how much fuel it takes to hold 1500RPM, you can control how much fuel it takes to get to 1500RPM and how long it takes to come to a stop. Acceleration and deceleration are your fuel wasters. Long periods of idle wastes fuel. Running gear drag (low tire pressure and thick oil) wastes fuel.
Old Jun 5, 2012 | 02:40 PM
enafzige's Avatar
Both. They accomplish different things.
Old Jun 5, 2012 | 03:29 PM
DodgeFreak's Avatar
Originally Posted by cougar
Other than a timing bump and better atomizing injectors, there is nothing more you can do to the engine. .
I'd have to disagree alittle on that part, My dads truck in his crew cab stock engine stock pump we was getting 20-21hwy mpg consistantly, I had his truck with me for a week and put the 3200 spring in and turned up the pump 1.5 turns and tightend the afc 2 turns (the torqs on top) and rotated the pin to the deepest setting, We are now getting 23-24 consistantly on the highway I could probably clean the smoke up alittle more and we'd get better, More power to an extent the more effeciant (sp?) you will get up to speed and maintain speed.......
Old Jun 5, 2012 | 04:25 PM
dieselJon's Avatar
Bumped timing and M&H
18cm housing on that HX35
Valet switch
Old Jun 5, 2012 | 07:37 PM
mtdoragary's Avatar
I've never messed with my pump, but it's got an M2 pin and the spacer. Exatly HOW do I turn it up one a half turns and tighten the AFC two turns? I have to make anumber of 1500 mile trips and I could USE an extra mile or two per gallon!
Old Jun 5, 2012 | 11:12 PM
BILTIT's Avatar
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
Old Jun 6, 2012 | 09:12 AM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
Remember to inflate your tires to the max written on the side wall. Clean air and fuel filters help too.
ronnyenns
Oct 21, 2009 07:38 AM
crewcabxlt
Feb 10, 2009 09:12 AM
kawi600
May 16, 2008 07:24 PM
Kman9090
Sep 19, 2006 11:25 AM
Katmandu
Feb 13, 2006 04:38 PM
