47rh rear trans mount ? 2wd
Old Apr 1, 2010 | 07:50 AM
kensmachine's Avatar
putting a 47rh in my 92 D250 anyone got a picture of what they did for the rear transmission mount Thanks Ken
Old Apr 2, 2010 | 03:58 PM
AUGIE DOG's Avatar
Look in the sticky...should be a complete write up on it.
Old Apr 2, 2010 | 05:49 PM
For the 4x4 yes but not for the 2wd trucks Ken
Old Apr 2, 2010 | 07:00 PM
archer39's Avatar
I can't picture a 2wd's mount but if it is any help you will need about 2" further back. If you cant modify the mount (again i cant picture what it looks like) could you more it back on the frame?
Old Apr 2, 2010 | 10:08 PM
I have it fingered out. You only have to move it back 1" the motor plate is 1 1/6 thicker. if it doesnt rain like a cow edit on flat rock tomorrow I will get it done Ken
Old Apr 4, 2010 | 07:23 PM
Got the cross member done. Other things to do when putting a 618 in. # 1. cut the ear off on the right side of transmission why if you don't the dip stick wont fit. #2 flatten the pinch seam out across the top of tunnel and on the right side right under the heater box where the seam starts to go up into the tunnel. I didn't find these things in the sticky. Ken
Old Apr 5, 2010 | 11:51 AM
AUGIE DOG's Avatar
I have a two whl drive and put a 47rh in my crew cab. I did not have same problems you are having with fit?? Hmmmmm?? What we did was drill holes in top flange of frame rails to move trans mount to rear. Sounds like you have trans mount fixed. Good luck, you will like the 47rh especially if you tow.
Old Apr 5, 2010 | 05:04 PM
getstucksome's Avatar
all that I did for my 47rh mount was drill the stock xmember and use a 2nd gen trans mount. I bent the stock 47rh dipstick to work with my truck
Old Apr 8, 2010 | 11:26 AM
Trans is in the truck and moving down the road need to put a pressure switch on it so the lock up drops out at about 40 mph. but it works good goes down the freeway about 400 rpm less than the 518 at a same mph. I rebuilt the trans before I put it in. things I did put in the trans is steel front plant,transgo shift kit,BD converter, a carbon fiber ridged front band,put 5 clutches in the front drum,and few other little goodies in it. my friend with a transmission shop was impressed in the way it shifted. hope I can get passed 20 mpg with it now Ken
cmann250
Nov 9, 2011 10:03 AM
Mclair
Aug 12, 2010 06:30 AM
stevectd
Oct 6, 2009 07:49 PM
kensmachine
May 3, 2009 12:41 PM
