4 inch exhaust
24V manifold will fit but the ports are oval and would need to be port matched with a bit of grinding work.
I was just going to do this since I had a 24V manifold and was doing the exhaust manifold gaskets but turned out my 24V manifold was cracked.
A HX-35 upgrade is a great upgrade for a 1st gen.
It will work well for towing, as long as you do not crank the fuel up to much. Things like really big injectors, might make it run too hot
thanks for that gotta get on this project so am going to start shopping for one, as i stated am going to put in second gen rad and intercooler also. want i little more pull power but something that doesnt overheat on the first big hill.
ok, just wandering how big is your exhaust pipe? i dont have at present to much trouble with egt,s but engine temp really gives me grief, gotta back rite off, and go slow, in the hills.thats why i am going to sec, gen rad and intercooler. thanks for the reply
4" pipe. Just EGTs... my engine (coolant) temps are fine.
If you are getting hot quickly like that it is likely heat coming from your auto transmission.
yes i know they can sure add some heat to things, but i have an upgraded torque, which helps a little, big aux cooler, and i do run a gauge, the gauge shows it doesnt get that hot in trans fluid. so i feel maybe in this case the rad is not quite up to par. quess i expect sometimes too much out of these old trucks
I have never had any of my Cummins trucks run hot, but they have all been manual shifted trucks.
