21 cm housing
21 cm housing
I dont really see anything on this housing can you long time DCD guys ID this from this photo or tell me where to look and provice serial## to look for? I suspect it is the 21cm and would like to upgrade. The truck will regularly pull 3,000-10,000lbs I have about 1500.00 to put into upgrades(not including trans) where would it be best spent for the best pulling power. Trans will be rebuilt next summer with good converter.
cant tell from the pic but if the truck is stock chances are so is teh housing.
1500 bucks..... crap, look at my sig. i dont think i spent that much on mine or just about right there. and it definatly gets out of its own way.
pods = 470 bucks
air intake system = 110 ish
4 inch stright pipe = 300-400
gauges = 250-300ish
3200 spring = 18 bucks.
custom fuel pin = 75
16cm housing = 150.
ok so maybe just below 1500.
pods = 470 bucks
gauges = 250-300ish
16cm housing = 150.
This page has a lot of good info on turbo's:
http://www.dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
You've either got the 18 or the 21. They show the casting numbers for the HX-35 but you've probably got the H1C. I don't know if they used the same housing.
Edwin
Edwin
I'm sure sombody else who knows for sure will jump in here anytime, but since you are a 92 and intercooled, you should have the 21 cm housing. From what I understand the non-ic trucks have the 18.5 and the IC have the 21.
Also, mine was a 90 non-ic and it did not have that heat sheild on the down pipe. Didn't even know that they used them.
There is alot of power to be made with $1500. The guys on here will lead you in the right direction in spending it wisely.
Adam
Adam
The numbers you are looking for are cast into the housing. They are facing the firewall. They are right near where the turbo bolts to the manifold. there are lots of numbers but there will be a 21 or 18.5 or 16. if its stock it will be 21 or maybe 18.5. 16CM were not stock but the best all around housing-IMHO
ajbirken
Sep 6, 2006 12:11 AM
95black2615
Jul 21, 2005 09:06 PM
HOHN
Dec 7, 2003 02:07 PM
