1st gen wont start
The lift pump runs on a cam so the motor needs to be in the right spot for the lift pump to have resistance and work.
Try bumping over the motor and try the LP again.
I would check the wire to the FSS and make sure it is not loose.
Yes the FSS can die.
I would try running a hot 12V jumper wire to the FSS from the battery and trying to start it normally.
If that doesn't work, then try this. If it is an auto leave it in Park, If standard leave it in neutral with the e-brake on and wheels chocked, cross the starter terminals with a jumper wire while the FSS has 12V power to it.
If that works you know the FSS is good, but some other bit of wiring is bad.
Sounds like the pump's up to pressure. If there's no flow, it'll feel like "nothing".
Odds are good he FSS took a crap, or the wiring to it. The power for the FSS, the A21 circuit I believe, goes all over the truck, powering the coil of the manifold heater relays, the FSS, the VSS, the automatic transmission OD solenoid, etc. A short anywhere will take the whole circuit out. It has no protective fuses except a fusible link, and the ignition switch, which will sometimes burn out to protect the fusible link.
Turn the key on. Check the terminal on the FSS for 12V. If there then the FSS is likely shot. If not, go find the fault in the power circuit.
92GhostRyder
Sep 16, 2018 12:02 PM
BRUISER
Feb 2, 2015 11:25 AM
pulltilbroke
Apr 10, 2009 02:08 PM
