1st gen towing tips
Old Jul 6, 2019 | 08:17 AM
SORTIE's Avatar
Originally Posted by KRB
Brakes are the weak link IMO
roger that; I should have said so directly. and don't even get me going on that lame-o excuse of a parking brake. That reminds me that I need to add to my signature the Mico lever lock I installed to keep my truck from drifting down the boat ramp, pulled by a three-ton boat & trailer. I never want to show up as one of the maroons on YouTube having my truck recovered from underwater!
Old Jul 6, 2019 | 08:34 AM
SORTIE's Avatar
I've been thinking about a dash cam for the traffic here in SoCal. Any suggestions on which type/brand. Is the rear view worth the extra?
forgot to answer this: the good news is that dash cams have gotten super-cheap. I don't even know what brand I have, but I paid less than $75 for it a couple of years ago and have velcro mounts in my truck and old M-B 300TD wagon. Recently I dropped it on the garage floor so the buttons no longer work (but it's still recording). Amazon Prime days are coming up on the 15-16th, I bet you can buy a camera with forward and reverse views for less than $50. Well worth the peace of mind given how much distracted/moronic driving occurs today. It won't prevent an accident, but it will memorialize it! The reverse cam will pick up the daredevil who comes up in the center lane (as you're in the slow lane) and suddenly cuts in front of you to make an exit a few hundred yards away (of course, there's no one behind you, these drivers are just impatient)f
Old Jul 7, 2019 | 09:44 AM
BHD's Avatar
BHD
The only reason I drive my '90 is when its hooked to a trailer. The heaviest I have been is 19k combined, in central Pennsyltucky with a grade every 2 miles. I have the G360, 4.10s and 315/75R16s (35's).
The single biggest improvements I have seen are 1)swapping out the non IC radiator to the IC radiator, 2) the 3200 rpm governor spring, 3) Denny T Stage 1 fuel pin.
I have put about 50K on the truck since doing the Getrag/4.10 swap and I have had no issues related to towing with the Getrag. Even in 5th gear on grades when the engine is on the higher end of the RPM spectrum.
Like Oliver said, spend the extra on a good gauge set. I have worked on quite a few later generation Dodges where the owner complains of high EGTs and the culprit is the Glowshift units.
Also like mentioned above, the brakes on these trucks SUCK. Good progressive brake controllers are worth their weight in gold.
Old Jul 7, 2019 | 10:01 AM
nonrev's Avatar
Super Moderator
10 Year Member
BHD, what rpms are you running at 60 with the 4:10s and what tire size are you running?
Old Jul 7, 2019 | 11:47 AM
BHD's Avatar
BHD
I don't have a tachometer, but I would guess just shy of 2000 at 60. Running a 35 inch tire
With the 3200rpm governor spring it tops out above 90mph
I really think the best combo for these trucks is 3.55s, 33 to 35 inch tire, HX35 turbo, and a fuel pin.
If money weren't an option and I could get the driveline angles to work a Brownie Box or Gear Vendors would be awesome to split all the gears for towing.
Old Jul 7, 2019 | 03:40 PM
j_martin's Avatar
Brakes are the weak link IMO. If I had a stick I'd be saving money for an exhaust brake and springs. Otherwise just make sure your trailer brakes are spot on.
I have a Goerend low stall torque converter in my automatic, and the engine brake is quite effective. I do 16,000 downhill on East Homestake with very little if any service brakes. (usage, all 5 axles have brakes) and at a pretty good clip as well.
Clearance in the torque converter is critical. Mine got knackered by a shift kit install mistake, where the installer put in the TQ pressure mod that's not needed. Over time it stretched the case a bit and braking quit being effective. Goerend warranteed the TC.
Old Jul 8, 2019 | 04:47 AM
KRB's Avatar
KRB
Good to know. Stock exhaust springs still?
Old Jul 8, 2019 | 11:06 AM
Shelby/Dakota's Avatar
5 Year Member
Thanks for all the advice guys. Guess ill add some items to the upgrade list LOL
Old Jul 9, 2019 | 03:59 PM
u2slow's Avatar
Just got back from hauling ~6k# of trailer. My truck is much more stable with an extra 1000-1500# in the bed.
Old Jul 9, 2019 | 08:53 PM
SORTIE's Avatar
with ten-leaf rear springs, mine is too
Old Jul 12, 2019 | 04:05 PM
Midnite's Avatar
Don't forget the larger wheel cylinders for the rear brakes. They can help quite a bit.
92GhostRyder
Sep 16, 2018 12:02 PM
BRUISER
Feb 2, 2015 11:25 AM
pulltilbroke
Apr 10, 2009 02:08 PM
redwake9112
Mar 5, 2007 11:35 PM
BigDodge1
Jun 25, 2005 09:57 PM
