1st Gen Electrical Emergency.
Today At School My Power Locks Wouldnt Work. I Went To Lunch And Went To Park At The Store, Applied The Parking Brake And Sparks Shot At My Feet And Smoke Filled The Cab From The Left Side Of The Cabin. The Abs Light And The Parking Brake Light Are On While Driving Down The Road. The Windows And Locks Are Intermintly Working And There Is No Sign Of Wirring Issues. All The Fuses Are Also Good. What Happened??? Im Pulkling The Dash Out Right Now. Please Help Me.
The parking brake mechanism has been known to chew through the wire bundle. That's what's happened here. Don't think there's need to pull the dash. You can view the wire bundle by getting on your back on the floor and looking up at the top of the parking brake assembly. It's also possible you fried on of the fusible links on the fender in the engine bay. But it doesn't sound like it since most of your stuff is working, at least part time. Pull one your battery cables off first so you don't make more sparks. Then repair whatever chewed up wires you find. If you still have problems, then you'll need to chase down the issue one-by-one.
Mine was smoking and sparking one time and it turned out to be a toasted wire in the steering column. I replaced it (I think that it was a wire that grounded the top of the column to the frame ??) and it has been OK since. Never did figure out why that wire was toasted but it was toasted up pretty good.
Good Day,
JP.
Good Day,
JP.
Good Day,
JP.
Good Day,
JP.
ok now the lights,door locks and horn don't work. my flashers, turns and backup lights work. i can get all my lights to work if i turn on the lights pull the trailer brake control lever and parley push on the brake pedal. i think the trailer brake controller is back feeding in to system. where is the fuse able link that i fried. please help me i had to drive 60 miles in the dark with just my flashers.
fusible links or on the driver's side fender. They're a pain. Most people, if they have to start messing with them, replace them with some sort of buss bar and breakers. I know AP Watson did this.
92GhostRyder
Sep 16, 2018 12:02 PM
BRUISER
Feb 2, 2015 11:25 AM
pulltilbroke
Apr 10, 2009 02:08 PM
