1992 W250 trans crossmember
Old Dec 17, 2010 | 07:58 PM
30dodgeboy's Avatar
Another question for the transmission conversion experts:
Is the 1st gen W250 (4wd) transmission crossmember the same between the 5speed and automatic trucks? A 1992 truck in particular.
I know Ford used the same crossmember bolted into a different set of holes between manual and automatic to accomodate the different lengths.
Unfortunately, I don't have one of each of the dodge stuff to answer the question myself.
Thanks in advance,
Art
Old Dec 17, 2010 | 08:32 PM
sooty's Avatar
same 205, different frame mount location
Old Dec 17, 2010 | 09:01 PM
SORTIE's Avatar
I found out that the trans cross member can be mounted backwards, causes all sorts of clearance problems if you replace the tx mounts (especially if you have a 4" exhaust)
Old Dec 18, 2010 | 06:38 AM
Subliminal's Avatar
The crossmembers are a little different. The 5 speed crossmember is slightly beefier, and also raises the Getrag up about 3/8 of an inch. It's got some boxed out work. Probably because the Getrag is so much heavier than the autos.
Mopar1973
Feb 1, 2014 09:31 AM
Thiss
Oct 20, 2010 09:16 AM
77machomopar
Mar 26, 2008 11:19 PM
Short Box
Apr 17, 2007 06:31 PM
JKM
Sep 27, 2005 02:47 PM
