fluctuating heat output and temp gauge.
When driving my temp gauge (factory) will bounce between the first mark and the second mark. It gradually increases to the second mark then will fall back to the first and continue to do this while driving. The heat output will also vary during this fluctuation.
Could a bad thermostat cause this? How about the head gasket? I don't have any mixing of oil and coolant and no bubbling in the overflow bottle that i have noticed.
its been in the 20s and 30s. it never did it in the past 3 winters i had the truck. the fan is still on the truck with nothing blocking the rad. I did not have these problems in past the heat always stayed a steady temp.
My 93 does it and has terrible heat (probably bad heater core too). Does it all times of year but more noticeable in the winter months.
My 89 always runs too cool and has mediocre heat.
My plan is new thermostat
if everything is in order, these trucks should cook you out, especially in a summer-like 20 degree.situation. with some cardboard in front of the rad, my truck blows very warm air at 30 below and colder. Warmer than -30 its almost too hot. it sounds like a tstat to me also if its a gradual increase and decrease, if the gauge is twitchy its probally a ground.
So at what outside temps is it alright to run without a fan? I've been lazy on doing the electric fans on the single cab so it still has the mechanical on it. It's "winter" here in sunny AZ, 65 was the high for today.
