16cm exhaust housing how hard is it?
The housing may or may not "fall" off the turbo when you take the four bolts out. Some penetrating lube like PB Blaster, Kroil, or the like and an overnight soak will go a long way to helping. Then tap tap tap around the housing. Easy does it. Keep turning the the shaft of the turbine/compressor to make sure you don't bind the housing against the turbine.
When I did mine, it was a son of a gun to get off. More like bang bang bang around the housing. I was scared I was going to damage the turbine or shaft. But it come off in the end. Just takes some time.
I had a HELL OF A TIME, getting mine off. BANG BANG BANG around the housing didn't work. Eventually in the end i made some wooden wedges out of 2x4 and hammered them in from either side and it came off like a dream. Lol. Housing it good mod though, hope you enjoy it.
Do you guys leave it the turbo bolted in place while or is this done on the shop floor? I was going to soak it with PB-blast for a week or so. I understand the idea- don't want to bind on the wheel. I was hoping with it mounted on the exhaust manifold-it might be easier to man-handle.
M
M
i took mine right off, swaped it on the bench. if it is tight use a dead blow or the handle end of a sledge. to tap with... put it back on tightened every thing up...iirc the oil drain was bichy to get back on and i striped out the threads on one side be carefull its aluminium
Firstgenfanatic
Aug 17, 2008 11:25 PM
ajbirken
Sep 6, 2006 12:11 AM
cumminsdriver635
50
Jan 16, 2006 11:02 AM
HOHN
Dec 7, 2003 02:07 PM
yea if it wasn't 20 years of heat cycles and rust on it
