12 cm housing no wastegate?
So I picked up an hx-35 off of a 95 ram, and the boost hose was cut on it, and it does not hook up to the turbo itself. Where should I run this line? I do have a set of gauges, and I was going to see how high the boost got before I hooked up my wastegate. I don't think I want to go any higher than 35 psi without head studs though. If I do have to hook my wastegate up, how do I adjust the turbo so that I can get over 20 pounds of boost out of it?
If you have the fuel you'll get well over 20 pounds of boost even with the gate hooked up.
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
wannadiesel
38
Sep 29, 2005 06:35 PM
