1990 dodge diesel radiator
Old Nov 26, 2005 | 07:42 PM
OLDDDOGS's Avatar
i have a 1990 dodge cummins powered with a 727 automatic pick up. The truck is stock. I would like to have a bigger radiator. Can somebody help me? will a newer truck radiator --91 or 92 fit?
Old Nov 26, 2005 | 08:01 PM
Micaiahfied's Avatar
mind if i ask why the need for the bigger radiator? the diesels, especially stock, don't usually have any problems overheating. i even know a few people who run most of the year with the fan pulled.
Old Nov 26, 2005 | 08:14 PM
bgilbert's Avatar
The non-intercooled trucks have much smaller radiators than intercooled trucks. Even at stock power when the truck is worked the way its intended they run hot.
Old Nov 26, 2005 | 09:29 PM
ok, i just picked up a non-ic 91... if i decide to put in the IC i should put in a larger Radiator as well?
Old Nov 27, 2005 | 05:53 PM
A member just installed a newer style radiator in a non-IC truck, the thread should be in the next page or two back. He didn't have a whole lot of trouble, but there was a little bit of tweaking involved.
Old Nov 27, 2005 | 07:19 PM
rebal's Avatar
YOU can install a 91.5 -93 cross flow with very little effort and some hand tools if you want info you can PM me or do a serach on it on this site. my 90 CTD has a 93 rad. in it and nolonger runs hot! 89-90 rads. are to small for them to do a good job
Old Nov 28, 2005 | 12:11 AM
JWP's Avatar
JWP
I just did this. I put a 93 radiator in my 89 truck. The main reason to do this is cost and you get a better radiator. The 93 radiator is a crossflow design and a little larger. I detailed what it took in my writeup. You should be able to find it pretty easy by searching.
8liter
Sep 22, 2012 10:19 AM
royzane
Feb 14, 2012 07:59 PM
MoparMarv
Jan 8, 2008 11:49 AM
mtman
Jul 10, 2006 12:53 PM
Captain Dean
Apr 30, 2006 11:01 AM
