wow - Overflow valve
Old May 18, 2009 | 09:29 PM
JohnX's Avatar
Ordered mine yesterday. I hope it does half of what you guys say.
Old May 19, 2009 | 07:05 AM
rynojr4644's Avatar
Got mine last night also ordered on Friday, I will put it on tonight. Thanks
Old May 19, 2009 | 08:35 AM
cmac's Avatar
ordered mine friday and got it monday!! holy fast shipping!! i'll put it on tonight
Old May 19, 2009 | 09:50 AM
infidel's Avatar
Originally Posted by HelenaTDI
Sweet bought one myself. Guy on ebay still has 4 left.
http://cgi.ebay.com/ebaymotors/ws/eB...m=250425345078
Actually he has a never ending supply.
Here's his new auction http://cgi.ebay.com/ebaymotors/BOSCH...1%7C240%3A1318
Old May 19, 2009 | 11:15 AM
rynojr4644's Avatar
Ya I started mine this morning and it started right up I gave it a little gas and it died first time in two days. Had to hold it to the floor to get it started took two times. Thought I had cured this problem with the AFC housing. Hope when I put this on tonight I have no more starting problems.
Question should I check fuel pressure first and then again after?
Thanks
Old May 19, 2009 | 06:34 PM
infidel's Avatar
If you check it before and the pressure is 17-22 psi at idle and 25-35 at 2500 rpm no load there is no reason to replace the valve.
Old May 20, 2009 | 01:00 AM
Buzz'nhalfdozen's Avatar
i ordered one too. i was seeing 14psi at idle before i installed the new one. with the new one i'm seeing 21psi at idle. hope to see an MPG improvement
Old May 20, 2009 | 07:37 AM
rynojr4644's Avatar
Didn't get to do it last night but when I was backing in the driveway the truck sounded like it was trying to die and loading up on fuel. I had to stop and run it up too 2000rpms to level it out. So Im guessing that mine is bad.
Old May 20, 2009 | 09:10 AM
White Ghost's Avatar
does anyone have a cummins part number?
Old May 20, 2009 | 09:51 AM
infidel's Avatar
Dodge 04883838AA
Cummins 3932096
Last I heard Cummins wanted $74 for the valve, Dodge over $100.
The ebay valve is exactly the same as the Cummins valve.
Old May 20, 2009 | 10:25 AM
thanks, that is exactly what i needed.
Old May 22, 2009 | 07:43 AM
rynojr4644's Avatar
Smile
Ok could not get my fuel pressure gauge on the the truck didn't have the right fitting in my $400 fuel pressure test kit. But when I got the old valve out the little spring was broke on the inside? I don't think I broke it put the new bosch valve in truck sound and drives better. Im sure with 235,000 on it it needed a new one. Also the truck started real smoth this morning and ideled perfect.
Thanks again for the info.
Old May 22, 2009 | 04:36 PM
cmac's Avatar
finally got mine put in and my first thoughts are, it starts easier, idles smoother, and no more white smoke. will post results of fuel milage when i have to fill up again.
Old May 22, 2009 | 05:49 PM
i ordered mine last night. i can't wait to see the difference in my truck. i hope the milage goes back up.
Old May 22, 2009 | 10:59 PM
12VRattler's Avatar
I too ordered mine, I checked my fuel pressure and it was sitting at 15 at idle and increases to 20 with a little throttle. When I pinched the return line, it instantly shot up to 60 psi so I think the overflow is my only fuel problem. When I dropped by my local cummins dealership, one of the mechanics gave me a banjo bolt to put on the filter housing on the outlet side that is threaded for 1/8 npt so I simply put a needle valve on it and hooked my guage up to it!
rbrettctd
Nov 11, 2008 01:42 PM
roadgeneral
Oct 17, 2007 06:54 PM
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
getblown5.9
Dec 18, 2005 08:28 PM
