weight of 12valve engine
Old Feb 26, 2006 | 03:55 PM
Flashpoint's Avatar
Anyone know what a cummins weighs? I maybe changing one out here in a few weeks. Has any of yall used a regular cherry picker engine hoist or is it to weak? May have to rent one heavier duty.
Old Feb 26, 2006 | 04:05 PM
dieselrob's Avatar
They are a little over a 1000lbs. My book says 1022 dry for the 24 valve.
Old Feb 26, 2006 | 04:14 PM
gmctd's Avatar
930lbs.............
Old Feb 26, 2006 | 10:56 PM
RedRider's Avatar
930 pounds is about right give or take
Old Feb 27, 2006 | 10:02 PM
MNf250's Avatar
Pulled my 95 12v out with just a plane old 2ton picker with no problems.
Old Feb 28, 2006 | 08:06 AM
gmctd's Avatar
Remove the u-frame carrying the radiator\charge-air cooler\ac condenser, so engine only needs be raised just above bumper heighth, and a standard 2klb engine puller will do it.
It is the length of the engine vs required lift vs load arm length that is of concern, since most of the pullers are min 2k load capable.
Old Feb 28, 2006 | 11:26 PM
RedRider's Avatar
i used a standard picker. the biggest problem i had was the engine is super long and hard to fit in there properly. top valve cover studs kept getting caught in the cowl insulation.
-Gary
John Marshe
Aug 14, 2020 09:00 PM
Purplezr2
Jul 25, 2011 04:31 PM
cwert87
Nov 28, 2008 09:19 PM
SilverHoss99
May 6, 2008 10:12 PM
Mostwanted
Feb 8, 2004 12:06 AM
