check engine light on 12valve
Old Feb 6, 2004 | 08:58 AM
Mostwanted's Avatar
bwat4 I have a california emmisined 12valve. The check engine light came on yesterday. I was driving very slow due to the adaverse weather conditions and all of a sudden the light comes on. I immeidiatly pulled off the road and check all the vital fluids, which seemed to be fine. What are the diffrent systems monitered by the computer? Should I just take it somwhere and have it checked?
Old Feb 6, 2004 | 09:29 AM
infidel's Avatar
Any problems identified by the check engine light are recorded and stored as fault codes. They can be accessed with no tools by following the instructions here-
http://dodgeram.org/tech/dsl/trouble..._DTC_codes.htm
Old Feb 6, 2004 | 10:08 AM
Dr. Evil's Avatar
Will this still work even though he has a 97???
"This procedure works for the 94-96 12 Valve engines. The 97-98 12 valve and the ISB all require the DRB diagnostic tool to obtain trouble codes. "
Old Feb 6, 2004 | 01:40 PM
bulthisl's Avatar
Was it the water in fuel light that maybe came on.
If so it may have picked up moisture from the adverse weather conditions.
: Eddie :
Old Feb 6, 2004 | 06:38 PM
infidel's Avatar
I think that may be a typo on dodgeram, as far as I know only '98 12 & 24 valves and '99 24s require a code reader.
Old Feb 7, 2004 | 09:14 PM
jman's Avatar
in 1996 all auto makers went to a obd II computer sys, before that it was a obd I, to get code from a obd II you need a scan tool of some sort, and to clear the codes out, hope this helps
Old Feb 8, 2004 | 12:06 AM
infidel's Avatar
You can still read the codes on everything except '98 & '99 with the key off/on trick, you can't clear them though.
BKR
Feb 14, 2013 06:22 PM
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
Flashpoint
Feb 28, 2006 11:26 PM
alltimelow1
Apr 6, 2005 07:28 PM
