Wastegate Frozen?
Old Sep 15, 2008 | 09:32 PM
  #31
ne_plus_ultra_1's Avatar
Boost line doesn't go to AFC from there.
It goes straight from turbo to actuator only, well it did before I blocked it off due to leakage.
The AFC boost line comes from manifold pressure in what is done so neatly it could only be a factory configuration (I assume).
You guys are awesome. Thanks for all the excellent replies thus far.
I picked up the 7.3 for my dorF today and pressure washed it. Gonna degrease it some more and spray it again tomorrow. I'm off of the Dodge for a few. I was supposed to pick up the 7.3 earlier but plans kept falling through...
I was really surprised that exhaust temps appeared lower with 1500 pounds in the bed, like less than 600 off a 70 mph highway run. Power appeared lower too.
Old Sep 16, 2008 | 10:17 AM
  #32
infidel's Avatar
This is the common way it's done on '97-'98 but never seen it done this way on a '95. Makes me wonder if someone swapped turbos.
Leave the wastegate blocked and don't worry about it till you add more fuel.
It will take quite a few more mods in order to cause an overboost situation.
Old Sep 16, 2008 | 10:38 AM
  #33
winkle's Avatar
And on '96, at least that the way mine is works. It goes straight from the waste gate actuator to the AFC.
Old Sep 16, 2008 | 12:56 PM
  #34
I'm telling you, I was removing factory clamps. It's so nicely done on the intake to AFC that I simply do not believe that anyone in Tampa did that work. Unless they really did take it to Tampa Mack, then maybe.
Wow, wouldn't it be a thrill to find that I have a newer engine with less miles on it? I guess unless it's the dreaded "53" block, whatever that means.
How can I check what engine I have??? Gotta be casting ## somewhere that Cummins could look up, eh?
7.3 engine job coming along nicely although not impressively speedily. Of course it is a different engine-different year-different wiring swap. Dash is almost out for the harness.
Old Sep 16, 2008 | 08:16 PM
  #35
97 D-Tec's Avatar
i dont think the 53 block was a 12v issue so you should be safe on that front as for the possible turbo swap just take it as a gift since it hasnt hurt anything
Old Sep 16, 2008 | 11:44 PM
  #36
bob4x4's Avatar
There are 53 block 12v's but I have yet to see one fail
Bob
sallyman1
Feb 10, 2008 06:17 PM
PupleDiesel
Oct 22, 2007 07:09 PM
Ramdriver15
Apr 15, 2007 10:15 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
