Damage from frozen wastegate?
Would a frozen wastegate linakage cause high EGT? And if it does, what damage does it do to the turbo?
I ask because I have to rebuild my turbo (excessive side to side play). During inspection/removal I've foung the wastagate linkage rusted fast. Truck came from NY east of lake Erie. '99 2nd gen w/ only 106K. Lift pump replaced w/ in-tank pump, IP is remanufactured. Judging by rusted/non-rusted bolts/nuts the turbo may have already been worked on.
Also, I'm a little confused on the clamp plate for the turbo housing. Mine only has 4 cap screws and Cummins rebuild buliten shows 6. What's up?
I'm fairly new to CDT and have a lot to learn. I read a lot of threads just so I don't have to ask something that's already been answered. Hopefuly, I'm not doing that now.
As long as the wastegate is frozen shut, your EGT's will be cooler if anything because it will be making more boost. If the wastegate is frozen open, then you will definately be low on power with high exhaust temperatures, and excessive smoke. If your truck is an automatic, then you will have the smaller turbo with a 9cm exhaust housing instead of the standard stick shift HX35 with a 12cm exhaust housing. The automatic turbo(HY-9) might have less bolts holding it together than the standard HX35. Hope this helps a little
Eric
Eric
This helps a lot. Real good explanation of turbo too. I really don't know how to determine which direction the wastegate is frozen. This is my first CTD so I don't know the "feel" of the power (yet). The turbo is HX35W. No smoke, but I wouldn't hold my hand near the exhaust tip for more than a few seconds.
Why such a smaller housing? 12 Vs 9 equates to 44% less area! Now I know why more people choose the 5/6 speed.
Would the wastegate issue cause premature turbo failure? Because that's what I have. I can move compressor wheel side to side and just barely touch the housing, but didn't touch when running (no marks).
Eric
The first time I dynoed my truck, it was on HRVP and Jammer2 sticks alone, no tuner or anything. Hit 300hp, 35psi, and it never defueled or threw a code.
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
