valve adjustment at 60k
hey guys,<br> <br>i just picked up my ctd about a month ago and need to know when i should get a valve adjustment and any other maintenance the last owner might have over looked. also i hear im due to fix the kdp if so where do i get a jig to repair it. my truck is a 96 with 62,350.<br><br>thanks, dan<br>
Re:valve adjustment at 60k
I would just go ahead and adjust the valves. That way you know what was done. Before you do check the gaskets on the valve covers. If they are black in color you probably should go to Cummins and pick up the upgraded gaskets. The upgrades are grey. They are about $28 for all six around here. If you already have the grey ones on the valves have probably been adjusted.<br>Tom
MnTom, when did you get your kdp fixed(milage), and do you know who i contact to get the jig . i cant remember where i saw the list to use or rent it? [undecided]
[quote author=cortez link=board=16;threadid=13197;start=0#124377 date=1049521906]<br>MnTom, when did you get your kdp fixed(milage), and do you know who i contact to get the jig . i cant remember where i saw the list to use or rent it? [undecided]<br>[/quote]<br><br>If your a member of the other site you can get on the list for the KDP jig...a few members of this site also have Jig Kits and have helped other members repair the KDP<br><br>Here's a page I built with step by step using a Jig Kit<br>http://www.phantomcycle.com/kdpfix.html
[quote author=cortez link=board=16;threadid=13197;start=0#124322 date=1049508471]
hey guys,
thanks, dan
[/quote]
HAROLDS KDP JIGS
harold has basic kdp jigs which include the jig, bushings, drilbits, 3 setscrews, all for 29.95 s&h included
he has the deluxe jig kit for 69.95 inclding s@h which has the jig, bushings, bits, tap, depth stop,t handle racheting wrench, t handle allan wrench, punch, 10 set screws,red locktite, detailed instructions, air pressure regulator devicre to presureize engine w/ air to keep shavings from entering engine when ya drill and tap.basicly everythin ya need to do a kdp fix cept for the fan hub wrench, drill, air comprsr, and a guy to do the job.[proly 4getin sumthin here] also 10 stickers to apply underhood area to let future owner of rigs ya fix know they have no need to worry bout the kdp causing problem cuz ya did the fix on it.
the advntage to harolds jig is if the pin has sliped part way out,the angle of the hole allows ya to tap the pin back into place. the 1st gen jig and 2nd gen jig are specific for their applications to asure no slop and a direct hit of the setscrew against the owelpin. the 2nd gen jig does the 12v and 24v. for those who dont know 89s thru 99s are in need of the kdp fix. the 8.3 also has this problem acording to a tdr thread
harolds email is rvhvnfn@juno.com ph is 208 459-7849. harold is in his rvhvnfn for a few days so if he dont get back to ya till next week that is why
http://www.nwbombers.com/board/ikonb...ST;f=11;t=2874
as to the valve adjust, harold, a club member does em on a 12v for 25 bucks.[during the weeek in his shop][ no charge at bomb parties]. too bad ya aint in idaho but im sure a member in your area can line ya up. check events sec for upcoming bomb parties in u area
valve adj is recomended every 30k on 12v, 100k on 24v
hey guys,
thanks, dan
[/quote]
HAROLDS KDP JIGS
