Hard to get into Reverse?
Old Apr 21, 2003 | 08:33 PM
97Dually's Avatar
I am new to a 5sp Dodge CTD. So, bear with me....
Is it normal to need to rock the truck a bit in 1St so that I can get the shifter to go into Reverse?
TJ
Old Apr 21, 2003 | 09:44 PM
bulthisl's Avatar
Re:Hard to get into Reverse?
Nope !<br><br> : Eddie : 8)
Old Apr 21, 2003 | 10:43 PM
97Dually's Avatar
I just figured that every truck had a bit of a sweet spot for getting it into reverse. I find I need to move the truck about a foot or so to get the reverse to lock in. If not, it grinds and won't go into reverse at all.<br><br>TJ
Old Apr 21, 2003 | 10:48 PM
phox_mulder's Avatar
I know, totally different animal, but. . .<br><br>On my Toyota, most of the time to get it into reverse I had to push in the clutch,<br>try reverse,<br>let clutch out, (in N) :<br>push clutch in again,<br>go into reverse smooth as bottom of baby.<br><br>Soon I just skipped step 2 and had no problems.<br><br>No idea if Toyota's had synchros or whatever, but it worked.<br><br>Just in idea.<br><br>phox
Old Apr 22, 2003 | 02:06 PM
dsljunkie's Avatar
My 97 has been tough to get into reverse since the day I got it. Im about to put a South Bend in her and we'll see if that helps <br> Wheels
Old Apr 22, 2003 | 06:08 PM
Dojman's Avatar
In my experience, it seems like most will eventually get in a bind of some kind and need to be nudged a little in some way to get it to go into gear, any gear,sittin still. If its an every time thing and/or gettin worse, and spreading to other gears, first and third come to mind, watch for problems(going out) IMO It may not have a thing to do with it, but I had the fifth gear nut back off twice on the 98.5 that I had and hard shifts(or hard to get to go in gear) were the warning signs. Unfortunately,sooner not later, I called the last one within two days of actually happening.
enydick
Aug 14, 2010 10:20 PM
The Goat Man
Feb 3, 2008 08:17 PM
jmccart
15
Nov 24, 2007 05:31 PM
Baja
Aug 20, 2007 01:08 PM
loveturbowine
15
Feb 24, 2005 05:44 PM
