Vallet Switch
Old May 6, 2004 | 09:46 AM
INJECTOR JACK's Avatar
Exclamation Vallet Switch
Has any body hooked up a Vallet Switch ?
Old May 6, 2004 | 11:02 AM
bulthisl's Avatar
I have before but I haven't put mine on yet.
I'm working on a way to make it varible.
I think I've got it figured out just haven't tested it yet.
It's getting busy time on the farm and haven't had much time.
: Eddie :
Old May 6, 2004 | 11:56 AM
Question Vallet Switch
I was wondering if you install the solenoid to cut off air to both the afc and wastegate or just the afc?
Old May 6, 2004 | 12:00 PM
signature600's Avatar
I'll bet you can, but WHY?
When you want the air to go to the pump, it would also go to the wastegate. You would want the wastegate to stay closed when the pump is getting full fuel.
Chris
Old May 6, 2004 | 02:55 PM
Question Vallet
The vallet switch is used to block of the afc so the engine does not get full fuel,You do this when engine is hot rodded so when some one else drives your truck they don't blow the engine up!
Old May 6, 2004 | 04:03 PM
I know that, I've got one.
What I meant was why would you want to cut the air to the wastegate AT THE SAME TIME as cutting the air to the pump? This, on my truck, would have no effect, as I have the wastegate set to open above 35psi, and in Valet mode All I can get at WOT at 85+ is 25psi.
Chris
Old May 6, 2004 | 04:14 PM
Forrest's Avatar
Muted User
With the Valet switch on, i'm getting 42psi @ 5200' elevation, 46psi @ 150' elevation. With it off, 12 or 14psi.
It'll be an interesting test with the Piersified 40 ... probably will get more than 12 or 14psi. More umph if so.
Old May 6, 2004 | 04:50 PM
vallet switch
My wastegate is feed from the pump, I was wondering if I should plumb it to cut off the afc only or if I should just plumb it with the the solenoid before the pump, so both afc and waste gate are both cut out? I have never seen one hooked up, Wondering how there plumped in?
Old May 6, 2004 | 09:19 PM
nascar mark's Avatar
You need more fuel Forrest!!!!
I can get 67psi/495rwhp with valet on and oh, a little more with it off.
Old May 6, 2004 | 09:50 PM
Forrest's Avatar
Muted User
Yea, but your packin dual monicas.
Old May 9, 2004 | 10:50 PM
matador's Avatar
Are you guys with valet switches running with them on at highway speeds to get better fuel economy or is the switch only for other drivers to keep them from rodding your trucks?
Or do you not even get enough power to run at highway speeds with the air shut off to the afc?
Matador
Old May 9, 2004 | 10:54 PM
Forrest's Avatar
Muted User
Hwy speeds are no problem. Even over the Sierra Nevada range, 7200' summit, no problem.
Lots less smoke & better mpg. I re-figured the mpg, forgot to add in some miles I drove before resetting the trip meter. It was only .4mpg less with the switch on.
I can't wait to try the Piersified 40 with the Valet switch.
Old May 10, 2004 | 12:49 AM
With no boost going to the AFC and the right setup your truck will still rock and can take 99% of vechicles on the road. We have made over 500rwhp and 1100ftlbs with the vallet on. What it does is it cuts a little over half your fuel flow in CC's so you can run around everyday with out blowing smoke when you don't want too.
smokeyram
Aug 21, 2009 06:19 PM
Barryn
Jul 14, 2008 09:30 AM
SPLnut
Dec 31, 2007 11:27 AM
redramnc
Mar 28, 2005 06:58 AM
kingofdodge7131
Feb 24, 2004 10:44 AM
