Vacuum pump/ transmission problems
Old Feb 14, 2014 | 12:00 AM
cowboysmoke's Avatar
Does the vacuum pump effect the shifting capabilities of the transmission? I have a 1996 12v 2500 4wd and recently it started not shifting into 3rd gear. It just dawned on me that at about the same time I developed a vacuum pump leak that caused braking problems. i was wondering if the transmission uses vacuum to shift??
Old Feb 14, 2014 | 09:05 AM
patdaly's Avatar
Nope.
Old Feb 16, 2014 | 08:50 PM
That was a GM thing.....never mopar. Depending on what tranny you have....47RH or 47RE.....your tranny is shifted either by "H"ydraulic input, or "E"lectronic control.
Old May 1, 2014 | 03:01 PM
Lil Dog's Avatar
Shifting issues are commonly due to wear in the TPS (Throttle Position Sensor). There are a large amount of posts here on that with some quick checks and fixes as well as suggested to just replace it. A quick search will have you busy.
Cheers.
coalburner_77
17
Nov 7, 2018 07:36 PM
jimbo486
May 8, 2016 06:07 PM
powerstrokin03
Mar 19, 2007 01:00 PM
amartinson
0
May 4, 2003 01:55 PM
