vaccum pump
Old May 28, 2005 | 02:24 AM
plow's Avatar
vaccum pump
would the vaccum pump leak air if the seals in between the power steering and pump were shot or would it just leak ps fluid?
Old May 28, 2005 | 04:17 AM
kenirwin's Avatar
Air leaks
They are two seperate pumps driven by a common shaft. The vacuum pump leaking would not show up as a power stearing fluid leak. By the way in 97 they didn't have ATF in the power stearing system so if you replace it make sure you use the correct fluid. Go to www.fixinrams.com for more info. If low vacuum is the issue, check for oil in the vacuum lines or an oil rotted rubber elbow attached to the vacuum pump outlet. Ken Irwin
Old Jun 2, 2005 | 11:37 PM
plow's Avatar
i do have oil in my vaccum lines. what does this mean?
Old Jun 3, 2005 | 01:09 AM
P.O.R.'s Avatar
you don't have a check valve in the vacuum line or it is bad if you do have one, they get gummed up,clean with break clean and also take each line off one at a time and flush out.
here is a link http://dodgeram.info/tsb/1997/D-97-10.htm
Old Jun 3, 2005 | 09:38 AM
infidel's Avatar
If I found oil in any vacuum lines I would replace all the contaminated hoses. If oil finds it's way to your climate control or 4wd switches it will melt them causing you more expense and repair hassle.
jeephauler
Jun 22, 2006 08:20 AM
GlennRMK
21
Aug 26, 2005 11:57 PM
rockjeep73
Jul 17, 2005 10:35 AM
signature600
Apr 11, 2005 07:33 AM
JCHMOTOR
Jan 8, 2004 09:56 PM
