Turbo Shaft Play
Turbo Shaft Play
I noticed today that my turbo shaft has some up and down play in it. I'm guessing 1/32" to maybe 1/16" (i didn't have a precise way to measure it). There isn't any rub marks on the inside so nothing is hitting. Also this is on the intake side.
Is this normal?
Thanks
Will
Is this normal?
Thanks
Will
The truck has 177,000 miles on it. Is there a kit to do the rebuild? How hard of a process is it?
I can't "feel" any fore to aft movement, it feels tight that way. There are no marks in the housing where it hit so i'm sure it hasn't made any contact.
I'll have to buy a good set of calipers and get a more accurate reading.
Thanks
Will
Thanks
Will
As long as its not rubbing the housing, i'd say just leave it alone. It should be fine. If you do decide to do rebuild it, its not that hard of a process, just takes a little time. IIRC they can be had for around $100 but im not positive.
captntim
Dec 26, 2008 02:53 PM
4x4dually
Jan 5, 2007 01:07 PM
Deezle98
Feb 17, 2006 11:41 AM
